06-17-2016 | #1 |
Power Antenna Question
Does anyone know where the power antenna wire is located in a 1991 ZR1? I want to install a switch i bought to shut off the power bc i dont use the radio and i do not want the antenna going up and down constantly
06-17-2016 | #2 |
Blue (I think) wire at the CDM box. Pass side of dash.. Or back behind the package cover on the driver side
06-17-2016 | #3 |
Re: Power Antenna Question
I thought the antennae only comes up when radio is ON?
06-17-2016 | #4 |
And when you play CD and if you are running navigation head unit which stays on all the time.
I installed a switch and keeps my antenna down. Around town, even with the antenna retracted, have no issue receiving FM and HD FM signal. |
06-17-2016 | #5 |
Marc installed one for me under the carpet behind the driver seat. Saves the up and down big time.
Jim 1990 Z # 2441 1959 c-1 230 HP 4 speed frost blue/silver 3 owner 2011 cts-v 556 HP, manual 6 speed 1955 chev 2dr ht PP 265 3 speed w/OD |
06-17-2016 | #6 |
My reception was terrible.. I replaced the antenna and it got better.. Ground strap is next
06-18-2016 | #7 |
where is the power wire that you splice a switch into?
06-18-2016 | #8 |
06-18-2016 | #9 |
on a 1990-1 passenger side there is a CDM. The main radio module, that is where. I don't have pictures though
06-18-2016 | #10 |
secondchance...
What unit do you have in you car?
