Old 06-16-2016   #1
Dafink
Default Injectors - Advice
OK, I'm going to undertake replacing the injectors. Does anyone have any words of wisdom before I start?
I am thinking of using these injectors -
http://www.ebay.com/itm/Chevy-Corvet...VRVliB&vxp=mtr
or -
https://www.summitracing.com/parts/acc-150821
Anyone have any experience? Also any resources or tips are appreciated.
Dafink is offline   Reply With Quote
Old 06-16-2016   #2
Default Re: Injectors - Advice
First, how can an injector be reconditioned? Maybe cleaned & tested constitutes "reconditioned".
FIC, a supporting vendor of the ZR-1 Net, "used" to offer "reconditioned" injectors, but no more. Reconditioned injectors are a hit & miss proposition. I recommend you avoid the eBay reconditioned injectors.
I do recommend FIC new, stainless steel injectors for the value and certainly for their customer service.
The Accel injectors also have a good track record, as does FIC. The last I knew, the Accel injectors required trimming the connector lock tab to install. Someone here with first-hand knowledge can verify that for you
Old 06-16-2016   #3
Arctic91
Arctic91's Avatar
I have installed Accel injectors (part number ACC-150821) in each of my cars, and have had no issues. I installed them in my 1991 about 9 yrs ago and installed them in my 1990 just last month.
A26B is right... a small alignment tab on the housings of primary injectors will need to be removed with a grinder. Very easy and it just takes a couple of mins to do all eight. I bought mine from Summit, and they seem to always have good prices.
Here's an article from Mark Haibeck's site, which should give you some additional details: http://zr1specialist.com/HAT%20Web/a...eplacement.pdf
Scott
'95 Callaway SNAT 450 Aerobody Coupe - Black/Black
'92 Callaway SNAT 400 Convertible - Polo Green/Beige
'91 ZR-1 #1231 - Arctic White/Saddle (SOLD)
'90 ZR-1 #2547 - Turquoise Metallic/Black
'89 Callaway Twin Turbo Aerobody Coupe #027 - Black/Black
'85 Corvette 454 Coupe - White/Red
Arctic91 is offline   Reply With Quote
Old 06-16-2016   #4
Accels continue to work flawlessly after 8 years.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-16-2016   #5
5ABI VT
I cant recall if it was RC that had them on special last year when I needed o rings. Im kicking myself for not getting them then but Im wanting to replace mine soon too.
Old 06-17-2016   #6
ZRXMAX
ZRXMAX's Avatar
I am coming up on 10 years with Accels and roughly 70K miles of service. The price was $526 from Summit for 16 when I bought mine if memory serves me right
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black
ZRXMAX is offline   Reply With Quote
Old 06-17-2016   #7
Dafink
Did you need to cut/modify the Accels?
Old 06-17-2016   #8
There's just an extra tab on the injector that is not necessary for installation. You can grind it or cut it off to install the harness connector. No issues otherwise.
Old 06-17-2016   #9
Kevin
Kevin's Avatar
fuelinjectorconnection.com discount and lifetime warranty for registry members
Old 06-17-2016   #10
RussMcB
These are the ones I went with last year. I'm happy with how my car is running.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
