Old 06-13-2016   #1
Chris26
Default Radiator Drain
I want to drain all of the coolant...Is there a drain plug???
Chris26 is offline   Reply With Quote
Old 06-13-2016   #2
efnfast
Default Re: Radiator Drain
There is a drain **** (valve) on the radiator, but that certainly won't drain all of the coolant.
Old 06-13-2016   #3
Chris26
Ok....I will need to pull the hose then..Looks like the drain **** will be getting
serviced.....
Old 06-13-2016   #4
Passenger side. Just a plastic turn screw.
Old 06-13-2016   #5
2ljd
Has anyone tried using the UView UV550000 on their LT5 to fill their cooling system? I understand that it's not the simplest process to fill an LT5 as air pockets are a common occurrence.
I've read about Mark's method of lifting the right side of the car, but was wondering if anyone has tried the UView system.
Thanks!
2ljd is offline   Reply With Quote
Old 06-13-2016   #6
efnfast
serviced.....
Apparently we don't like drain c*o*c*k*'s. Site blocks it.
Old 06-13-2016   #7
Thanks!
Nope but Marc's method old school as it is works fine. GC
Old 06-13-2016   #8
JimZRyd
JimZRyd's Avatar
I used Marc's method of lifting up the right side recently on my 94. Didn't think I had to as the cooling manifolds were heating up as they should...just wasn't getting in as much as I removed. Lifted the right side up till she bubbled and was able to easily get more in. Weird in my opinion but oh well, it worked!
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 06-13-2016   #9
2ljd
Thanks all, I'll try the UView tool first and if I run into problems, at least I know I can fall back on Mark's method.
