Old 06-09-2016   #1
scottskill
Default Hi Idle
Help, I have a dilemma! Just finished porting the intake system not including the cylinder head, recalls the chip,headers, and unfortunately cleaned the throttle body! At this point in time I'm having Hi idle problems, 2k rpm start up lowering to 1100/1500 rpm. Placed cardboard in front of airhorn while engine running and continues to run @ Hi idle. Used propane around the vacuum fittings, gasket mating areas,injectors with no increase in Hi idle rpm. My question is what steps shall I try to accomplish next to get this idle corrected?
scottskill is offline   Reply With Quote
Old 06-09-2016   #2
Default Re: Hi Idle
Go back and recheck all your work, I'll bet its a vacuum issue, double check all the lines.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-09-2016   #3
Default Re: Hi Idle
Vacuum for sure! No/little change w/ a piece of cardboard blocking the air horn?
the brake booster hose?
the PVC line to the plenum and the
the purge vacuum line next to it?
the HVAC line or SPT line(s) - one on either side of the center plenum
the vacuum line (90s) under the plenum on the air horn
check the fuel pressure regulator hose @ back of the plenum
PVC housing and hoses (back of plenum)
secondary port throttle vacuum
And, then there's the plenum gaskets, IH gaskets and the Throttle Body gaskets...
Any of the above. (In RED are some that caused the problem on mine, specifically.)
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-09-2016   #4
Default Re: Hi Idle
I'm assuming you disconnected the throttle cable and removed the IAC motor.
The Min Air adjustment at idle of the throttle blades may be required. Also a reset of the IAC motor if it was removed from the throttle body. That's a good place to start.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-09-2016   #5
scottskill
Default Re: Hi Idle
Yes I removed the IAC, however I can't find a thread on how to reset the IAC? Also the thread for throttle blade clearance?
Old 06-09-2016   #6
Racinfan83
Default Re: Hi Idle
MAP sensor hose connection at rear of plenum was leaking causing my high idle issue....
[LEFT][SIGPIC][/SIGPIC][/LEFT]
[CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER]
Old 06-10-2016   #7
Billy Mild
Default Re: Hi Idle
Sounds like a vacuum leak more so then a throttle blade issue.
Do you have a mityvac to test with?
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 06-10-2016   #8
Default Re: Hi Idle
Min Air adjustment IS a vacuum leak.
Old 06-10-2016   #9
Billy Mild
Default Re: Hi Idle
I'm talking about a vacuum hose, not a throttlebody issue. If he used a piece of cardboard to cover the airhorn and the idle was still high that points to a vacuum leak AFTER the throttle blades.
Looking for a ZR-1
Old 06-10-2016   #10
scottskill
Default Re: Hi Idle
Yes, I have a mityvac. Next step isolate each vacuum line independently.
