Old 06-08-2016   #1
Chris26
Default 1990 zr1 help continued...
Does the ICM control spark and the injectors or both???
Chris26 is offline   Reply With Quote
Old 06-08-2016   #2
Default Re: 1990 zr1 help continued...
The ECM controls spark timing, the ICM CONTROLS START-up, limp home mode,
And firing of ignition coils. Injectors are controlled by ECM.
Old 06-08-2016   #3
Chris26
Thank you!!!...I might have a fried ICM (under the plenum)...seems that mice got into the valley at one point and caused a small fire!!! The engine did start before but not anymore.
Old 06-09-2016   #4
Oh, that ain't good, for sure! But, don't jump to conclusions until you have the harness repaired...speaking from experience w/ burnt harnesses. There are fuses and fusible links scattered about that may have done their job.
I'd concentrate on the harness - getting that back in shape, scanning it for codes, and go from there. I'd say (hope) your chances are better than 50-50 that the modules will be OK (they ARE very robust!)
Old 06-09-2016   #5
Chris26
Thanks for the reply!!! The harness is not that bad just a little seared..
Someone at one time installed an extra hot lead that connected directly from the battery to the alternator...they ran it under the plenum...Seems that a mouse chewed on it and created a ground through the block...with all the dirt and debris
igniting a small fireball. The secondary port actuators have the vacuum lines melted...
