Old 05-30-2016   #1
8cam
Default Clutch master cylinder replacement question
Yesterday I replaced the clutch master cylinder because of a badly leaking original. Not too difficult a job really once I figured out all the little things, and I'm sure I could cut the time in half now. Hardest part was that damn clip on the pushrod. My wrist still hurts from the twisting.
One thing I noticed about my replacement, the flange is considerably thicker than the original. That means when I add the spacer, it sits further from the firewall and the pushrod throw is a bit less. I can feel this in the pedal, definitely a shorter throw and the difference is noticeable. Everything seems to work fine - I was careful to prime the cylinder before installing, so I don't believe I have any air in the system. And the car drives just fine, but the clutch definitely feels different, shorter, than it did, and a little less positive effort. It's almost like it would feel with air in the line. Is there any issue with this? Or should I look for a different master with the thinner flange?
I am going to recheck it today and try to get any air out.
'90 ZR-1 #1322 Daily Driver, 64k and counting
Black/Gray
[IMG]http://i208.photobucket.com/albums/bb49/mlitherland/IMG_0326_zps3d50d8cb.jpg[/IMG]
8cam is offline   Reply With Quote
Old 06-01-2016   #2
ghlkal
ghlkal's Avatar
Default Re: Clutch master cylinder replacement question
I'm sorry I can't give you a good answer, but what brand master did you use?
I used a Dorman and I didn't think to compare it to what was on there before (which I don't know if it was original or not), but it must have been similar in size since I didn't notice a difference in the pedal afterwards.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 06-01-2016   #3
8cam
I ordered it from Eckler's, reasonably priced and supposedly the correct part. It is a bit different from the original, but it works. The reservoir cap is a much better design and the cylinder itself seems a bit larger diameter. The biggest difference is that flange thickness.
But after I popped the cap and pumped it a couple dozen times, then put about 20 miles on the car, the clutch feels MUCH better, better in fact than it ever has. The pedal requires a bit more effort now and the feel is way improved from the leaky original - I had no idea how bad it was. So yes, the design is a bit different, but it is installed and working well. I'm really happy with the improvement, and even happier I don't have to keep adding fluid to it any more.
Black/Gray
Old 06-02-2016   #4
ghlkal
ghlkal's Avatar
Great.
Yeah, I had been carrying a bottle of fluid with me ... maybe I can leave that home now
