Old 05-28-2016   #1
Dafink
Default Code help h55 and h64
So my car is throwing codes h55 and h64. It's riding rough around 3000 rpms and the power seems limited.
Anyone familiar with this problem?
Dafink is offline   Reply With Quote
Old 05-29-2016   #2
MuRCieLaGo
Default Re: Code help h55 and h64
We're two! See my thread here:
http://www.zr1.net/forum/showthread.php?t=26445
Keep me updated if you find something! Are your codes intermittent? What year is your ZR-1?
EDIT: I searched and I noticed yours is a 1991, just like mine.
Take also a look at this thread there:
http://www.corvetteforum.com/forums/...-and-64-a.html
Changing my o2 sensors is my next step.
MuRCieLaGo is offline   Reply With Quote
Old 05-29-2016   #3
Dafink
Seems like it's either the O2 sensor or ecm, leaning towards ecm since it feels like power mode is not getting selected. Does that make sense?
Old 05-29-2016   #4
MuRCieLaGo
What do you mean by "power mode is not getting selected"? For your information, when you got a SES light, you can't enable "Full engine power".
Old 05-29-2016   #5
Dafink
I think if there is an issue with the ecm it can result in the power mode being "unselectable"
Interestingly I drove it again this morning and it seemed to run fine, now I'm wondering how far to push it before diving in deeper.
Old 05-29-2016   #6
bdw18_123
If the check engine light is on, the ECM won't let full power mode turn on, even if the code is not related to the secondary system.
Old 07-13-2016   #7
Dafink
Swapped out the injectors and all is good now....!
Old 07-13-2016   #8
32valvesftw
For future reference, the GM Service Technology Group Fuel and Emissions Course handbook, states that Code 55 is "Fuel Lean Monitor" It gives 3 possible causes
1. Secondary ignition insulation fault
2. Lean Injector
3. Inlet filter restriction to injector.
Code 64 is "right Oxygen Sensor signal-lean"
It gives several causes one of which is injector restriction - right bank
So it looks to me like you nailed it by changing out the offending injector. Good work.
