Old 05-25-2016   #1
32valvesftw
Default predecessor to the LT intake system
Check out this review of an old Toyota by Regular cars. You may have to struggle thru the beginning but the explanation of the intake system makes me think it is very similar to our arrangement with primary and secondary runners.
https://www.youtube.com/watch?v=dNF5...el=RegularCars
Old 05-26-2016   #2
Default Re: predecessor to the LT intake system
The Ford/Yamaha 3.0L motor had similar setup w it's "bundle of snakes" intake.
Old 05-26-2016   #3
32valvesftw
I liked that motor but was not aware that only 1/2 the snakes were alive until needed.
Old 05-26-2016   #4
I owned several of them from 90-94 and then the V-8 version, which I didn't care for. There were secondary throttle actuators there that opened up the shorter runners for top end.
Old 05-31-2016   #5
Hog
The 1992-95 CPI 4.3 V6 found in the S-10 SS and ZR2/Highrider and some of the vans also had a variable geometry manifold. It was rated at 190-200hp@4500rpm/260lb/ft torque@3400-3600rpm.
The ECM opens and closes a door at a certain rpm which helps to provide low rpm torque, while still allowing for upper rpm power
In 1996 GM went to the CSFI L35(Vortec) with a standard intake manifold and CSFI spider injection with true sequential injection. In the fullsize trucks it was rated at 200hp@4600rpm/260lb/ft torque@2800rpm. This engine would out accelerate the TBI 350(200hp@4000rp,/300lb/ft torque@ trucks when installed in an equally equipped truck(gearing, cab and bed configuration)
Old 05-31-2016   #6
I made it to the 60 second mark.
