Old 05-24-2016   #1
Default Tire damage: A head scratcher...
Got home from MR4 and BG and parked the car. It sat there in the garage for a week before I had time to wash and clean it up.
So, I pull out of the garage drive 30 yards or so to my wash area. While washing the A-molds, I notice the RF tire pressure appears to be a little low. But, by the time I get done with the drying/spritzing/polishing a few minutes later, the tire is almost flat.
After re-inflating and inspecting the tire, I find what looks at first like a cut in the sidewall extending from the rim edge half way across the sidewall. And, it is leaking bad enough to feel a breeze on the back of my hand when passed near the "cut".
However, the grass was just mowed (short) and there is nothing I could find that could cut a sidewall that way. And, there was no bruising around the damage to indicate something had punctured the sidewall. (Not a mark on the rim either, tho the split runs right up to the rim!)
I've seen tire damage and repaired hundreds of flats while working at a service station (back before gas stations turned into mini-marts). But, this is strange...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-24-2016   #2
BigJohn
BigJohn's Avatar
Default Re: Tire damage: A head scratcher...
Box Cutter?
Old 05-24-2016   #3
Originally Posted by BigJohn View Post
Box Cutter?
Hmmmm.... Hadn't thought of vandalism.
90 #1202
Sans secondaries
Old 05-24-2016   #4
rush91
How old are the tires? What make? I've seen tires do weird things..... I've notice using lots or any tire shine, tends to wear out the rubber faster. Drys it out. Do you remember, maybe that tire going off the road, or pothole on the MR4 run?
rush91 is offline   Reply With Quote
Old 05-24-2016   #5
mike100
I ran over some sheet metal from a heater duct in Los Angeles on interstate 5 once...it was already smashed flat from some previous vehicles, but I tried to straddle it down the center of my Z28...
the upturned corner just cut the inside part of the sidewall and pretty much took out that Goodyear Gatorback. I didn't hardly feel anything, but a mile down the road it was flop flop flop and hard to drive straight.
Old 05-24-2016   #6
RussMcB
Paul, the picture isn't displaying properly. :-)
Old 05-24-2016   #7
32valvesftw
You probably hit something on the way home and it just let go when you moved it. Be glad it let go when it did.
Old 05-24-2016   #8
Jagdpanzer
Jagdpanzer's Avatar
A head scratcher...
Paul, how big are the cats where you live?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-24-2016   #9
ZRapid-1
Sounds like the short drive from the garage to washing area flexed the tire enough to cause the cut to finally start leaking.
1. If it's deliberate vandalism, check your other tires for damage.
2. Could be caused by road debris. Recent damage now failing.
3. How old are the tires? Older damage now failing?
ZRapid-1 is offline   Reply With Quote
Old 05-24-2016   #10
Racinfan83
So you are saying from the rim TOWARD the tread? Seems that would be hard to do by hitting something on the road/on your property without cutting the whole sidewall since the sidewall bulges out a bit..
How old is the tire? Could have cracked on it's own I guess.. Kinda is a stumper though. I too used to work in a service station and fixed tires can't remember seeing what you described..
[LEFT][SIGPIC][/SIGPIC][/LEFT]
[CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER]
