Old 05-21-2016   #1
Arctic91
Arctic91's Avatar
Default Injector Question (with photo)
Can any of the fuel injector experts out there tell me if this looks like an original injector on a 1990? I have a miss and sputtering that seems to be a weak coil or bad plug wire, but could be injectors failing. Thanks and sorry for the gigantic picture!
Arctic91 is offline   Reply With Quote
Old 05-21-2016   #2
secondchance
Default Re: Injector Question (with photo)
Scott,
You need to pull the injector connector off to see enough of the injector to identify. Metal clip can be slide down and out (don't try to pull it off completely) and the connector pulls up.
Old 05-21-2016   #3
Arctic91
Arctic91's Avatar
Thanks, Yun... I can try to get in there tomorrow and pop the connector off.
Scott
