Old 05-19-2016   #1
Bob Eyres
Default Exhaust Backpressure- 3" vs. 2 1/2"
In case you still believe that old theory that "you need a little backpressure in that exhaust system to get the most out of your engine", check out this Hot Rod Network video of back to back dyno runs on a Hi-Po 454:
http://www.hotrod.com/news/1605-engi...-inch-exhaust/
They also address the issue of variation in overall weight.
Old 05-20-2016   #2
Hog
Default Re: Exhaust Backpressure- 3" vs. 2 1/2"
Excellent comparison, boy are we spoiled nowadays. Engine dynos with data graphs and overlays that can be pulled up in seconds. A lot different than it was done back when these Mark 4 BBC's were being developed.
It would have been interesting to see the difference between open headers with the 18" collector extensions compared with the same open headers without the extensions.
Dropping the exhaust on any header equipped vehicle I have owned has always been greeted by a massive drop in low rpm torque, but sure screams up top. But my examples were usually low duration hydraulic roller cams set up for low-mid rpm torque.
It would have been nice to see a set of Corvette style BBC manifolds tried as well. The manifolds/Camaro exhaust on the 1969 ZL-1 Camaro with the all aluminum ZL1 427 BBC brought the 500-535hp output of the ZL1 427 down to about 275hp as per testing done at the Tonawanda plant. Chev knew that the buyers of these cars were going drag racing and would be ripping the stock Camaro manifolds and exhaust off of them anyways, so why design a complete new exhaust for only 69 cars.
I'm sure the 2 or 3(depending who you're talking to) ZL=1 Corvettes stock exhaust would cut into the power a bunch as well, although there would be more incentive to do a better exhaust for the Vettes, as there was the ZL-1 cars, and the 20 L88's for 67, 80 for 68 and 116 for 1969.
Good thread on the more rare BBC Chev cars with famous RPO's(now-back when new, very few even knew what RPO ZL1 or L88 entailed)
http://www.zr1.net/forum/showthread....hlight=ZL1+L88
Old 05-20-2016   #3
Mystic ZR-1
Mystic ZR-1's Avatar
BBC...
blah blah blah....
You could get a Big Block in a school bus!
(I'll bet they had a 3" exhaust too...)
But they never picked up the little darlings in an LT5
powered bus... not even the "Short Bus" that a few of us rode...
Old 05-20-2016   #4
BigJohn
BigJohn's Avatar
BBC...
blah blah blah....
School Bus ; you could put an LT5 in one if you wanted to.
You can find them in street rods, impalas, pickup trucks, 55 & 57 Chevys and boats!
Old 05-20-2016   #5
Mystic ZR-1
But the General never put 'em there!
Old 05-21-2016   #6
Bob Eyres
Not to change the subject, but..it's my thread so, did you ever wonder why the hell you would put an LT5 in anything but a C4 ZR-1?
And the only answer could be aesthetics right? It just looks better than any other Chevy engine.
If I had any one of those vehicles the only reason I would have to put an LT5 in it would be looks.
So, why not to put an LT5 in anything other than a C4 ZR-1?
- Expensive - If you can find one. No new crate motors available, just NOS.
- Heavy - Way heavier than any modern Chevy engine of comparable horsepower.
- More difficult to install - nobody has a plug and play CCU setup do they?
- Replacement Parts availability - Sure, you can get parts, but availability, and price, is nothing like it is for LS, or other crate motors.
- Not easy, or cheap to modify - For the price of a Haibeck 500hp upgrade, you can buy or build a motor with WAY more performance.
Bottom line, you gotta really love the LT5...and I do.
Old 05-21-2016   #7
BigJohn
BigJohn's Avatar
Yes, the looks, the rarity and dumb money!
With many ZR-1's being wrecked and stripped; the LT5 and it's computer are available.
Old 05-21-2016   #8
I'd love to do a 2Gen Camaro Z-28 w either an LT-5 or and LSx block/MMarine DOHC heads, ZF-6 or Tremec.
Old 05-21-2016   #9
RussMcB
CCU = Engine Computer? Yes, Megasquirt has one now.
Old 05-22-2016   #10
Hog
CCU=Computer Control Unit??
ECM=Engine Control Module
TCM=Trans " "
PCM=Powertrain Control Module (controls both Engine and trans)
