Old 01-06-2007   #1
key_on
Default Bose amps
Has anyone tried rebuilding the Bose amps? I know there is a procedure out there detailing how it is done, but I'm interested in hearing from anyone who has actually done it. I'm proficient at electronic assembly and soldering, but am concerned about removal of the epoxy used to stabilize the capacitors. Not sure how much board damage to expect.
key_on is offline   Reply With Quote
Old 01-16-2007   #2
Cdn ZR1 Mike
Cdn ZR1 Mike's Avatar
Default Re: Bose amps
you could use a bose amp from any Nissan that uses a BOSE speaker also. I tried using speakers form a 2005 Pathfinder and it worked great!!! Faster than rebuilding.
Cdn ZR1 Mike is offline   Reply With Quote
Old 01-17-2007   #3
Jeffvette
Faster for you since you went to the parts been and pulled them out. Your boss find out yet?
Old 01-17-2007   #4
Ccmano
I used the Nissan/Infinity Bose amps as well, a quick and cheap alternative. System sounds good.
Hans
Old 01-18-2007   #5
key_on
Thanks for the tip. I'll check out the local boneyards.
