![]() Join Date: Nov 2014
I just got my headers installed on my Z and I want to give a shout out to Dempsey at Evolution Motorsports and his crew. Speaking to car shops near me I actually saved money driving 4.5 hours to Virginia, getting a hotel, and going out to eat for 2 days while I had my headers installed, a plenum/ IH coolant delete, and a dyno for less than what shops here would have charged me for only the installation. I did not trust any local shops by me as they had no experience working on the LT5. Dempsey's shop did a great job and I got to tour Fredericksburg. I've never let anyone else touch my cars previously but I felt safe knowing Dempsey was an expert working on his 2-3 ZR-1s.
Lastly I'd like to thank Robert from Michigan, Ricky from NJ, and the Wazoo president Jim. I never would have bought my beauty without the advice from Robert and the help of Jim/ Young changing my injectors from the gecko. The ZR-1 brotherhood runs DEEP......Merica!!!!!!!!!! ![]() Last edited by Johnny5; 05-17-2016 at 02:38 AM. |
![]() Join Date: Aug 2006
Great to hear you got your headers and ported IH installed.
How did she do on the dyno? If you don't want to publicize send me a message. I'm real glad Dempsey opened a shop near me. I hate working on my cars other than the Z. Thanks, Dempsey! |
Hey Young! 374.5 to the rear wheels. So that is about 460hp crank if 18% is lost. I was told his dyno is more accurate and gives lower numbers than other dynos.
![]() Join Date: Mar 2007
Mustang vs Dynojet
"It's been said that a man with a watch always knows the correct time, but a man with two watches is never really sure. Unfortunately, there are no proverbs about a man with two knowing how much power his car really makes. In this article, we'll examine two popular chassis dynamometers and explain why each will give us a different rear-wheel horsepower for the same engine. We test both the Dynojet model 248 chassis dyno located at Strope's Speed Shop in Washington, Pennsylvania and the MD-250 Mustang chassis dyno located at Speed Nation in McDonald, Pennsylvania. We also performed testing at Keystone Raceway in New Alexandria, Pennsylvania, using a dyno system from West Automotive Performance Engineering. Dynojet The Dynojet chassis dyno is referred to as an inertia-type dynamometer, because large drums provide an inertial load to the drivetrain instead of a friction brake. The working end of the Dynojet includes two 48-inch diameter drums that are mostly below the surface and driven by the vehicle's drive wheels. In the photos of the Dynojet, notice how the rear wheels are centered on the drums and there is one drum per wheel. This will become important later. The vehicle is typically run in the transmission gear closest to 1:1 (Forth gear for manuals and Third gear for automatics) to or a variable load that maintains a preset engine rpm or vehicle speed. This feature is ideal for forcing the vehicle to operate at certain loads for tuning. The Dynojet can also measure air/fuel ratio while testing. Mustang The Mustang chassis dyno uses an Inertia load as well as an eddycurrent brake load to simulate the "actual" load (combined aerodynamic plus rolling frictional load) that the vehicle would experience when in motion. Notice in the photos how the rear wheels sit between two smaller 10.7-inch diameter rollers. There has been some discussion about the tires getting "pinched" between the rollers and creating more rolling friction, but no substantial evidence of this could be found. However, Mustang has a dyno (MD-1750) with a single 50-inch diameter roller per wheel that alleviates the wheel-pinch concerns. The internals of the Mustang dyno are composed of an eddy current brake to provide a variable load and an inertial disc to provide a fixed load. Mustang claims because its dyno loads the vehicle as it would be on the road, you can perform 0-60 mph, 0-100 mph, and quarter-mile measurements on its chassis dyno. Speed Nation has obtained quarter mile times within 0.1 second of actual runs at the track. We're not sure how the launch dynamics are simulated on the Mustang dyno, which includes weight transfer, acceleration, jerk (the derivative of acceleration - how fast the acceleration occurs) and some other variables. The Mustang dyno can also measure the air/fuel ratio while testing. CorrectIon Factors Correction factors are used by both dynos to account for varying atmospheric conditions such as temperature, pressure, and humidity. The measured horsepower and torque are multiplied by the correction factor to obtain the corrected values. This is similar to the corrected times and speeds provided by some quarter mile tracks. Theoretically, you can dyno on a hot day in the high altitude of Denver and on some other cool day at sea level and produce the same corrected horsepower even though the observed horsepower you are producing at each location is different. Both dynos calculate a correction factor based on a Society of Automotive Engineering document (SAE-J1349). When testing was performed on the Dynojet, the correction factor was 1.10, which means the observed numbers were multiplied by 1.10 (adding 10 percent) to get the corrected values. The correction factor for the day when testing was performed on the Mustang dyno was 0.9595 (removing 4.05 percent). The correction factor when road-testing at Keystone Raceway was 0.962, a correction reduction of 3.8 percent. Testing Testing was performed on each dyno using a '00 six-speed Z28 Camaro. We measured the horsepower and torque versus engine rpm in Second, Third, and Fourth gear. The test data also included how fast the engine accelerated in Second and Third gear (in rpm versus time) to be compared with actual road tests to assess each dyno's loading of the drivetrain. After each individual test we let the engine coolant temperature as displayed by our AutoTap OBD-II scanner to read between 200 and 205 degrees F for consistency. Dynojet sent out a representative to Strope's Speed Shop to verify calibration and witness testing. Calibration for the Dynojet is just a matter of verifying that the computer's configure file has the proper load-roller inertia factor. There are no manual calibrations for the Dynojet. The road tests were pertorrned at Keystone Raceway to provide a level surface to measure the vehicle's rpm versus time in Second and Third gear using AutoTap. Chad Fellabaum of C&C Racing in Pennsylvania weighed the car so the exact weight could be used for the Mustang dyno loading to be compared with the road tests. The dyno curve charts show horsepower and torque versus rpm in Third gears for both chassis dynos. You can also see that the Dynojet dyno measures a higher rear-wheel horsepower than the Mustang dyno. The Dynojet measured 5.1 percent higher horsepower in Fourth gear, 7 percent higher horsepower in Third gear, and 8.2 percent higher horsepower in Second gear. We will try and explain this difference a little later. Graphs 8 and 9 show the engine rpm versus time when the vehicle was loaded by the Dynojet dyno, Mustang dyno, and the actual road loading at Keystone Raceway in Third gear. You can see that the Mustang dyno loaded the car much closer to the actual loading in Second and Third gears. Why Is loading the Vehicle Important? The answer to this Question is twofold. First, the engine produces horsepower at the flywheel (brake horsepower) that is reported by the automobile manufacturers. Engine power is coupled to the rear wheels by a transmission and a rearend. But this is no free ride - there are losses in both the trans and the rearend. Therefore, the power to the rear wheels is equal to the flywheel horsepower minus the drivetrain power loss. The drivetrain losses are mainly composed of three loss areas: friction loss, inertia loss, and viscous loss. The friction loss is largely due to the surfaces of the gear teeth rubbing against each other. Gear friction is related to the torque being transmitted through the drivetrain. The gear power loss is related to the speed at which the torque is being transmitted. This is why it is recommended to have a transmission cooler for towing. The transmission must couple more torque to pull the boat resulting in more frictional power loss, which shows up as more heat in the transmission to be taken away by the transmission cooler. Inertial loss is related to the rotational acceleration (i.e., angular acceleration) of the drivetrain components. The inertial loss does not result in a power loss (i.e., heat) but absorbs energy that can be coupled to the rear wheels. This energy actually gets stored in the drivetrain components. The stored inertial energy in the flywheel keeps the revs up while the clutch is pressed in during shifts. The inertia loss is more pronounced in lower gears (i.e., First or Second) when the acceleration is highest. The viscous loss is basically the pumping of lubrication fluid in the transmission and the rearend. This is one reason why you get better e.t's when the drivetrain is warm, because the oil is thinner and provides less "pumping loss." Therefore, to measure the actual rear-wheel horsepower, the drivetrain must be properly loaded to obtain the correct drivetrain loss. If the dyno provides a lower drivetrain load, then the drivetrain losses will be lower and the resulting rear-wheel horsepower will be higher. The second reason why vehicle loading is important is that the newer computer-controlled vehicles use engine load as a control parameter. For example, ignition timing is a function of engine load. You will see higher timing advance when revving the engine in Neutral than you will when the vehicle is fully loaded at wide-open throttle in Third gear. This engine loading factor (and airflow dynamics, which is beyond the scope of this article) can help explain why some people have dyno'd identical to a friend's engine on a Dynojet dyno but got different results on a Mustang dyno. Which Dyno Measures the Actual Rear-Wheel Horsepower? West Automotive Performance Engineering has developed a proprietary device that independently measures a vehicle's actual speed and acceleration. This device is similar in operation to a fifth wheel but doesn't use accelerometers that can be influenced by the vehicle's body tilt. Using the vehicle's speed, acceleration, and weight (mass) and the application of simple physics equations, the exact horsepower and torque can be calculated. The horsepower and torque measured by West Automotive Performance Engineering's dyno is actually the horsepower made-good, or the horsepower left over to accelerate the vehicle after all the aerodynamic and rolling-friction losses have been overcome. These losses were accounted for and included West Automotive Performance Engineering's dyno so that a comparison with a chassis dynamometer can be made. The Mustang dyno includes the aerodynamic load that it places on the drivetrain as part of its reported rear-wheel horsepower and torque. Stated another way, the Mustang dyno does not measure the horsepower made-good. Graphs 7 and 10 show the horsepower and torque versus rpm in Second and Third gear, respectively, for the Dynojet dyno, the Mustang dyno, and from road testing with the dyno from West Automotive Performance Engineering. You can see that the horsepower and the torque, as measured on the road, are closer to the Mustang dyno measurements. Also from the acceleration tests you can see how the Mustang dyno loads the vehicle very closely to how it will be actually loaded on the road. Based on our test data, the Mustang dyno loaded our test vehicle and measured the rearwheel horsepower closer to what the vehicle experiences on the road. Conclusions The Test Results table summarizes the testing that we performed. Keep in mind that the peak numbers are influenced by the amount of smoothing or averaging done to the final data. For comparing dyno plots to determine losses or gains, don't focus on the peak values but take a visual average by comparing the before and after curves on the same graph. If you can't see a marked improvement on the dyno, you probably won't see a performance improvement on the street. Also, realize that both the Dynojet and Mustang chassis dynamometers are useful tools that have excellent repeatability. Both dynos measure the correct horsepower and torque for the load that they apply. Both dynos will show losses or gains from modifications. It is recommended that you pick a dyno for your baseline testing and stick with that dyno type and dyno location (and dyno operator) for subsequent testing. Always start at the same engine coolant temperatures before each run. Also, use an OBD-II diagnostic scanner like AutoTap (from B&B Electronics) to monitor your engine's operating parameters. This will provide the best indication of power improvements or losses. We like to monitor the engine-coolant temperature, timing advance, knock retard, pre-cat O2 voltage, and rpm. Monitoring the engine-coolant temperature lets you make sure your engine is at the same temperature before each run to produce the most consistent results. The timing advance and knock retard indicate if any detonation is occurring that results in reduced timing and lower horsepower. After doing some research, the pre-cat O2 voltage can provide a correlation to the air/fuel ratio even though the O2 sensors are not too reliable in this air/fuel ratio region. The bottom line: dyno numbers are for show, and track times are for the dough! -author unknown
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 05-17-2016 at 12:34 AM. |
based upon the test looks like a 393.6 would be the dynojet number
#7 | |
![]() Join Date: Nov 2007
Dynojet produced my initial base line (SAE) results. So, I'll stick w/ the Dynojet, going forward, I recon. But, I do appreciate the the fact that the Mustang dyno will attempt to account for some actual loss factors, better than the pure inertia (Dynojet), especially when comparing dissimilar vehicles: e.g., comparing a 730± hp Dodge Challenger (with aero properties close to a sinter block!) to a (Corvette). Anyway... I'm very glad to see Demps opening his shop on the east coast. It will add to the availability where our beloved Zs can be properly serviced; promoting the efforts to "KEEPING THE LEGEND ALIVE"! ![]() |
#9 |
what mph?
#10 |
113mph
