05-09-2016 | #1 |
Low RPMs bucking
Hi,
'91 ZR-1. Valet key always ON. I'm getting severe buckings at WOT when I'm under 3,500 RPM. High RPM is fine, pulls strong. For 3 or 4 miles this morning the car felt like it was running on 7 cylinders, from 1,000 RPM to 7,000 RPM. I took a 400 miles ride and it never happened again. Fuel consumption was good. However, the low RPMs bucking is still happening. It's been like this since I bought the car 3,000 miles ago. Warm or not. New from this year though: sometimes, the RPM needle would jump from 4,000 RPM to 1,000 RPM suddenly only for a moment (total power loss), then immediately comes back to 4,000 RPM. Happens especially when the car isn't fully warmed up yet. No SES light. I electrically tested the injectors last fall and everything was perfect. You guys got an idea? Is it normal to get bucking at low RPMs? Last edited by MuRCieLaGo; 05-09-2016 at 12:24 PM. |
05-09-2016 | #2 |
Re: Low RPMs bucking
Have you done a tuneup or changed O2 sensors?
05-09-2016 | #3 |
I recently changed the headers and added a o2 sensor 2 feet extension on passenger side. I also had Marc Haibeck burn me a chip.
05-09-2016 | #4 |
The bucking has not changed at all?
I would at least throw a set of new spark plugs in it. If that doesn't help then start looking at coils and wires. I have a similar issue except my car isn't always noticeable.
05-09-2016 | #5 |
1. Sounds like a closed loop issue
2. You recently altered O2 sensor wiring 3. Bucking you describe can be directly associated with a single bank, shorted O2 sensor 4. Shorted O2 sensor symptoms will disappear in open loop, i.e. above 3200rpm Recommend you check there first. Verify extension is properly wired, & make sure the connections are dry inside, no moisture. Do not tie back the extension underneath the AC condensate drain. Ask me how I know :-)
05-09-2016 | #6 | ||
Like I said, no SES light. I check the codes even if I don't have a SES light and no code is stored. |
05-09-2016 | #7 |
Keep your foot in it and continue the bucking. See if it sets a code. You may see a Code 61 and a Code 44. The bucking may be due to a bad fuel pump.
05-10-2016 | #8 |
check both map sensor hoses
05-10-2016 | #9 | |
Both? There's only one hose there... |
05-10-2016 | #10 |
one under the ecm
