Old 05-07-2016   #1
secondchance
Default HID driving lights
With LED headlights installed, driving lights looked like a pair of candles. So, I decided to try out a pair of HID driving lights. Tried LEDs first, but they did not generate sufficient lumens.
Light bulbs
Halogen vs. HID light patterns
On the car comparison
Both sides installed
Headlights and driving lights
These are 35W ballasts and 5000k color temp. 55W are also available in various color temps.
Old 05-07-2016   #2
Billy Mild
Default Re: HID driving lights
What was your method to fixing foglight with the LED headlights?
Old 05-07-2016   #3
secondchance
Cut green driving light ground wire coming out of relay and ground directly to the chassis - Hib's suggestion.
Old 05-07-2016   #4
G-Sting
G-Sting's Avatar
Those look like they work awesome.
Where were they purchased?
'94 ZR1 LT5 - Dark Red Metallic
'79 L82 4-speeds of fun
'96 LT1 Borla, H-pipe, TB, CAI (Sold)
"An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton
G-Sting is offline   Reply With Quote
Old 05-07-2016   #5
secondchance
Hidkitlights.com. This kit seems very similar to corvettemods.com kit.
Old 05-07-2016   #6
Mystic ZR-1
Mystic ZR-1's Avatar
Stock fog lites are a waste of electrons...
Old 05-07-2016   #7
secondchance
Back in 1984, they were the state of the art. You remember when the halogen bulbs were introduced. Right? Before we had candles.
Old 05-07-2016   #8
ghlkal
ghlkal's Avatar
I had been thinking about trying some LEDs for the driving lights.
Which ones did you try?
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 05-08-2016   #9
secondchance
One of those ebay $35 LEDs. Just wasn't bright enough.
Old 05-08-2016   #10
ZR1North
I've installed the HID "fog lights" too (fr Corvette Mods). First time I drove with them at night was on a country road, and I didn't even turn on my LED headlights; the HID driving lights were enough. These, and the LED headlights are awesome mods for C4s.
For those that have difficulty accessing the "green wire" coming of the fog light relay socket (it's not easy to get at), I wrote up a short description under the heading of GE Nighthawk LED headlight replacement here on the Registry. You just have to pop the relay and cut the terminal on the relay that plugs into the socket to which the green wire is attached. You can then run a wire from what is left of the cut terminal on the relay to ground. If you ever want to go back to stock (for reasons I would not understand), you simply replace the relay; all factory wiring remains in place.
ZR1North is offline   Reply With Quote
