Old 04-19-2016   #1
hotrodeddy
Default Clutch won't release
Clutch pedal pushes down to easy and doesn't release to shift into gear. Everything worked great when I put it away for the winter. I'm the original owner with 13,000 miles and was stored in a heated garage. No sign of any fluid leaks and is not low on fluid. Any ideas what to look for?
hotrodeddy is offline   Reply With Quote
Old 04-19-2016   #2
Hib Halverson
Default Re: Clutch won't release
When you say
Originally Posted by hotrodeddy View Post
Clutch pedal pushes down to easy and doesn't release to shift into gear. (snip)
Do you mean that, when you push on the clutch, it stays on the floor after you remove your foot?
Or, do you mean you can push the clutch to the floor and once it's on the floor you can't shift into any gear but, but when you retract your foot the pedal comes back up?
What model year is your ZR-1?
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 04-20-2016   #3
hotrodeddy
my z is a 1990 and yes the clutch pedal is easyer to push down than normal and it does return but can't get it to go into grear when depressed
Old 05-10-2016   #4
cuisinartvette
Either you have air in the system or its shot
Old 05-11-2016   #5
Racinfan83
Call Jim: http://powertorquesystems.com/Contact.htm
Old 05-11-2016   #6
thirstyzr1
I had a leaky slave cylinder and *** soon as the fluid level was low enough I lost the clutch. Pedal would go to the floor and stay there.
thirstyzr1 is offline   Reply With Quote
