Old 03-28-2016   #1
Billy Mild
Default Speedo Gears replacement
Currently I have speedo healer that I believe is causing issues with my Cruise control. I want to fix the speedo the right way.
I saw this on ebay. These appear to fix the speedo with gears versus another box to "heal" the signal. Has anyone used them? http://www.ebay.com/itm/231641706490...%3AMEBIDX%3AIT
How hard is it to change these gears?
Old 03-28-2016   #2
Scrrem
Scrrem's Avatar
Default Re: Speedo Gears replacement
I have never heard anyone who has had good luck with those boxes. Changing the gears is not too bad, you will need to removed the exhaust, drive shaft and the speed sensor, remove a retainer and slip the gear off the tail shaft. Some folks can remove their drive shaft without disconnecting the C-beam, I wasn't so lucky. Marc H. sells the gears you need.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 03-28-2016   #3
WVZR-1
Much depends on your rear axle ratio, if 3.73 or "less" numerically it's a single easily changed VSS driven. If it's 3.90 and up it takes a "pair", drive in the transmission and driven on the VSS>
The eBay link you posted doesn't mention anything specific so maybe after the "buy" you need to tell them what it is you have but 3.73 you don't need the "pair" like they mention.
It appears that Marc no longer has the 3.73 single gear. Marc can do the 3.90 & the 4.10 only it appears OR that's all that's advertised!!
Old 03-28-2016   #4
I think for the 3.73 you just need a 43 tooth driven gear.. where as the 3.90 or 4.10 you need the smaller custom drive gear and different driven gear
this might help
http://www.transmissioncenter.org/GM...eter_Gears.htm
Old 03-28-2016   #5
WVZR-1
this might help
45 tooth for the VSS for a 3.73 using the OE drive and of course same dimension tires to match the 315/35
The eBay link does mention to specify axle ratio when doing the order.
Interesting experience with the 3.07 - I'll email you
Old 03-28-2016   #6
Billy Mild
I have 3.73's. At least that is what I was told.
Old 03-28-2016   #7
WVZR-1
Confirm you have the 3.73 and if your tires are 315/35 OR very close dimensionally you need the "hardest to find 45 tooth driven" I had a few but I've got I believe just one now and a 3.73 gear new in the box so it's saved for it.
