01-01-2007 | #1 |
Cam timing?
is there a video that shows how to time the cams in our motor>? what special tools are needed and where can one get them. Or is there someone I could pay to set thew cams . I could drive the motor to them ? anyone got any ideas//help? reason replaced head gaskets due to orange junk.
01-02-2007 | #2 | |
Re: Cam timing?
Uly Past OWNER 90 ZR-1 #0120 Red/Saddle UT Plate: EZR1DER |
01-02-2007 | #3 |
Re: Cam timing?
thanx ully i give hima try
01-02-2007 | #4 | |
Re: Cam timing?
http://www.zr1specialist.com/HAT%20W..._camshafts.htm You will definitely find your 0.1 horsepower and then some by doing the cam timing...you need some special tools and quite a bit of patience...
01-02-2007 | #5 |
Re: Cam timing?
I think I would have had Corey do it while it was there. That, and port the heads while he was at it. 430+ then!!!!!!! Hell, maybe 440 with your numbers.
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 |
01-02-2007 | #6 |
Re: Cam timing?
I forgot that Milstead did a write up on timing the cams too...
http://www.zr1netregistry.com/cam.htm
01-02-2007 | #7 |
Re: Cam timing?
Guys the black car that I took to Coreys Is doing fine . The head gasket problem is with my red 90. SO I was going to do a 368 with it but Corey is backed up with the new shop so I thought I would put the head gasket in it and ddrive it till corey was ready. Ya know Its really hard on one to own 2 zr1s
01-04-2007 | #8 |
Re: Cam timing?
My mistake. I would send Jeffvette a pm. You could probably work something out with him.
01-04-2007 | #9 | |
Re: Cam timing?
01-06-2007 | #10 |
Re: Cam timing?
I think previous owner had dexcool in her. the motor dynod decent 347rwhpA157k miles with borla ex and z-industries chip . So decided to pull the motor and just replace both head gaskets . one ? how much is it to get the heads ported? and who. Coreys busier than hell who could I send the heads to that would do a good job. plus who has tensioners?
