![]() Join Date: Nov 2011
I find a couple of my shocks are leaking.
I'm going to stick with the Bilstiens. From what I see, Bilstien will rebuild them, but isn't thrilled about it. What is a good source to buy them? TIA. - Steve Last edited by ZBrink; 01-24-2025 at 08:43 PM. Reason: Title Edit |
Charlie, that part number does not seem to be an adjustable shock. They don't show shocks for our cars.
![]() Join Date: Jan 2015
I bought my new shocks from AJ USA a year ago (www.ajusa.com (800) 877-1911 in San Diego, CA) that time they were shown on the web site. Maybe you could call them. They had the best price.
Another option is www.deltavee.net I spent a few minutes on the phone with them and got a very good feeling that they're knowledgeable and experienced with FX3 shocks. They might be able to rebuild your current shocks. Last edited by ZBrink; 01-24-2025 at 08:36 PM. |
Just ordered them from AJ. Copied the number from the Bilstien site. The AJ site had them, but couldn't confirm they would fit the car. I could have been patient and called them........
![]() Join Date: Jun 2005
If you are looking for replacement Selective Ride Control (SRC) shocks, remember, there are two types of those shocks, early (89-91) and late (92-95). They do not interchange. If you install the incorrect type, the system will malfunction and set codes.
For more info see:http://www.corvetteactioncenter.com/...fx3/index.html My last information was that Bilstein USA has stopped rebuilding SRC shocks due to lack of some parts, but I'd call them to confirm that. Last edited by ZBrink; 01-24-2025 at 08:39 PM. |
I don't know what the proper Bilstein PNs are. All I know is there is one shock for 89-91 and another for 92-95. I have a bunch of extra shocks and I'd have to go get them out of storage and look on the shock bodies for the PNs. Can't do that right now.
From the shock's perspective, the differeces are 1) the bypass valve travel is different 2) the late shocks have a secondary valve stack in the bypass circuit which improves damping in the lower steps and 3) damping which is more aggressive overall because of lower spring rates for MY92-up Someone might ask: can you update an early system to the late shocks and the answer is likely yes but....you also need the late controller, or the Bilstein motorsports controller loaded with the late OE cal. I'm going to guess that, with Bilstein likely no longer rebulding them, and the supply of new shocks getting close to exhaustion, used, good-condition SRC shocks are going to become like "gold" in the ZR-1 communiry. It's a good thing that the shocks themselves were interchangeable between all C4s within the early and late series. That is, you find a set of useable SRC shocks on a 93 convertible in a junkyard, they'll work on a 93 ZR-1 just fine. Lastly, if, in fact, Bilstein is no longer rebuilding them that, also, may mean that the famed "Moraca" valving Bilstein used to offer is gone forever. ![]()
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 03-05-2016 at 01:40 PM. Reason: added content. |
![]() Join Date: May 2010
A few weeks ago when I was deciding to keep or sell all of the old FX3 shocks I had laying around, the tech at Bilstein was patient and kind enough to allow me to read off all the part numbers from the different shocks. They stated they only rebuild Bilstein aftermarket shocks and not any of the shocks that came as OEM on the cars or sold by GM and their part numbers.
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#9 |
So now that I've jumped the gun and possibly ordered the wrong shocks, how much oil on the tube is normal? Thanks for all the responses.
#10 |
A long shot but maybe worth pursuing: Find someone with a shock dyno and have them test your shocks. That will tell you for sure if your shocks are okay or need work.
I'd bet Delta Vee.com has a shock dyno. http://deltavee.net/shop/services/bi...ild-service-2/ |
