Old 02-04-2016   #1
Jitse
Default Crank plugs
Today I started with the rebuild of my 368.
Recieved last week the block, crank and heads back from the machineshop.
I am not sure if there needs to be a freeze plug in the front, behind the damper bolt? Or is the damper bolt keeping the oil pressure....
I was looking already in many topics here with the search option but could not find a clear anwer.
The crank is polished, they removed the treaded plugs and the freeze plugs in the walls where not removed. Installed new treaded plugs myself after checking for any more dirt.
Machineshop cleaned crank ultrasoon.
Jitse is offline   Reply With Quote
Old 02-04-2016   #2
Default Re: Crank plugs
Get the expansion plug style plugs welded in at a minimum
http://www.zr1.net/forum/showthread....ght=crank+plug
http://www.zr1.net/forum/showthread....&highlight=380
Old 02-05-2016   #3
Jitse
Thats something what can be done as extra security , a tig weld on those expansion plugs.
This crank is not regrind and not heated up like the regrind (380) from yours and Secondchance.... Or maybe they installed a mismatching set of freeze plugs in them that time.
Old 02-05-2016   #4
Jagdpanzer
Jagdpanzer's Avatar
The damper retainer bolt is installed in the crank shaft with loctite which seals the threads from leaking oil. I've done a few and so far none have leaked. Be sure to clean the bolt and thread bore and aply loctite liberally on the first half of the bolt threads.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-05-2016   #5
That's my recommendation REGARDLESS of the build. However I suspect the rework on the crank was the full reason the OEM method was not satisfactory. Too many $$$ these days in the rebuild to not do it IMHO.
Old 02-05-2016   #6
Jitse
Thanks for the good and helpfull replies
Today I installed the eagle rods on the Diamond pistons and started with file fit the rings, time consuming job. But I enjoy it.
