Old 01-24-2016   #1
Default Inj 1 fues keeps blowing
A month or so ago I had the plenum off my 1991 368. I noticed an electrical smell coming from the valley. One of the coils was very hot...so I pulled the coils off the coil housing and swapped them.
I also had the Inj 1 fuse blow. It now blows any time the ignition switch is turned on, except when I disconnect the two wire plug that goes onto the coil housing.(pnk/blck)
So is the coil housing possible the culprit? It all encased wiring
Thoughts?
Its CKT 639
Old 01-25-2016   #2
Default Re: Inj 1 fues keeps blowing
I did not see any pinched wires on the injectors
Old 01-25-2016   #3
Bent pin in a connector?
otherwise without me having a ckt diagram it is hard to troubleshoot
Old 01-25-2016   #4
I checked all of the pins, no issues.....the coils, DIS, and the primary injectors are on this circuit. As the initial issue with the coil was with them plenum off I wonder if its the Coil housing.
Old 01-25-2016   #5
Lee,
You should be able to check the housing for short as improbable as that may be.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 01-25-2016   #6
what changed on the car from when it was not popping the fuse to when it started popping the fuse
Old 01-25-2016   #7
Pulled Plenum to address a coolant leak...when the plenum was off I noticed the electrical smell from the coil
Old 01-25-2016   #8
I would suspect the bad coil that overheated rather than the base. If the base were to short, then there wouldn't be any voltage to the coil to cause the overheat.
Old 01-25-2016   #9
Coils changed, problem continues
Old 01-25-2016   #10
secondchance
Bad injector? Wouldn't coils be on separate ignition circuit and injectors on injector circuit?
