Old 01-11-2016   #1
Default Alert to 1990 ZR-1 Owners. NEW PART
Just arrived today!
BTW, A fellow ZR-1er loaned me a good quality, original connector at BG this year. I need to send his back with a nice thank you for loaning it to me. If you are that guy, excuse me for forgetting your name & please contact me.
http://www.jerrysgaskets.com/connect...-new-1990-000/
[I][COLOR=#ff0000][B]JERRYS LT5 GASKETS & PARTS[/B][/COLOR][/I]
[URL="http://www.jerrysgaskets.com"][U][COLOR=blue]http://www.jerrysgaskets.com[/COLOR][/U][/URL]
1994 [B][I]ZR-1[/I][/B], Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc.
Old 01-11-2016   #2
Default Re: Alert to 1990 ZR-1 Owners. NEW PART
Nice... makes me with I had a 90
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 01-11-2016   #3
efnfast
Nice, I heard Jerry was working on these.
Old 01-11-2016   #4
902066
Yea, thanks. Please keep the unobtainable parts coming.
902066 is offline   Reply With Quote
Old 01-12-2016   #5
W i l l
Very nice. Thanks for the support Jerry.
W i l l is offline   Reply With Quote
Old 01-12-2016   #6
Jerry.....I might add that the three PCV connectors (actually four as there are two Injector Housing Connectors) are also a great improvement.
These three connectors are compatible with 1990 - 1995 ZR-1s
Jerry's Dual PCV Valve Connector
Jerry's Dual PCV Valve Connector Hose
Jerry's Dual PCV Valve Connector Grommet
I installed Jerry's New Dual PCV Connectors on ALL engines getting rid of all the Clap Trap Nylon Ties and Hose Clamps to keep the Old (hardened Rubber) Dual PCV connectors from slipping off the PCV valves/lines or leaking Highly Recommended
Right up near Top Of List with Blocking TB Coolant at each Injector Housing.
Old 01-13-2016   #7
efnfast
Just arrived today!
Jerry, I'll take credit for that loaned part.- Steve
