Old 12-25-2015   #1
Dime
Default Damn oil drain plug
Well, was just out trying to change my oil. Easy enough right? Well I don't know what the hell I did last time (apparently I was mad and juicing at the time), but I couldn't get the plug to budge one bit. Started to round the plug some.
So, being the genius I am, I just grabbed a set of vise grips knowing that this would get it loose. ("I'll just order a new plug anyway.") Tapped it a bit, pulled and pulled, and rounded the plug some more.
Question is, applying heat safe?
I'll go back out tomorrow and see if I can get a cheater bar on there some how as well.
Thanks
Dime is offline   Reply With Quote
Old 12-25-2015   #2
Default Re: Damn oil drain plug
When they get rounded too bad for a box end wrench or a 6pt socket, try an 8" pipe wrench with a cheater. Holds better than vise grips.
Old 12-25-2015   #3
Yes....concur.....the pipe wrench gets tighter with torque and that 8 inch should be perfect
(use a large box wrench with box on pipe wrench handle or pipe as a cheater).
But before you use 8 inch pipe wrench get yourself a New OEM Oil Pan Drain Plug
Or Aftermarket Oil Pan Drain Plug
and the Seal Washer
A little heat directed at the existing plug might help.
Oil Pan Drain Plug (14 mm Box wrench).....38 ft-lbs (5/8-18 Thread).....actually a bit less torque with a bit of Permatex on the washer/threads.
I never use a torque wrench on Oil Pan Plugs.....just a 14mm box wrench and pull about "this" much which is not too much
Old 12-25-2015   #4
Jagdpanzer
Jagdpanzer's Avatar
Give the head of the plug a couple of good raps with a shop hammer and use a 6 point socket as Jerry suggests and it will come right out.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-26-2015   #5
WVZR-1
Hello Cliff - Engine Oil Drain Plug is by design a 9/16" HEX
Yes to the short pipe wrench suggested by Jerry if the OP has issues.
I have a few NOS Drain Plugs and maybe a couple of the Magnetic Inserted.
Old 12-26-2015   #6
Hi Dave: I am always a bit different as you know
The Oil Drain Plug .................9/16 is .5625 inches (14.2875 mm)
The Battery Cable bolt .......... 5/16 is .3125 inches (7.9375 mm)
Just now I had to go out and confirm on two ZR-1s
For the Oil Pan Drain Plug the 14 mm actually fits just a tiny bit tighter than the 9/16 which is good.
For the Battery Cable Bolts to Battery Connection the 8 mm fits just a tiny bit more loose than the 5/16 which is fine.
Both the 14mm and 8mm flex head ratchet box open end wrenches are perfect for the set of Tools to Carry in the ZR-1
Old 12-26-2015   #7
WVZR-1
Yes I do know about the bit different LOL and having NOS drain plugs BUT having always used a 9/16 box end I had to take a NOS drain plug and try the M14 after seeing this thread. An M14 wouldn't fit the NOS drain plug. An older drain plug is quite likely a fit. It's been a few years since we discussed the battery terminal bolt hex requirements.
Old 12-26-2015   #8
Ha....yep.....you know what I would do in the case of a NOS drain plug
I would take it to my grind wheel or even a flat file in a vice for about 10 seconds
That would then be MNOS....not a case of get the right tool....but a case of get the right Drain Plug
My best little modification is on the Belt Tensioner with a flat file (a 10 second modification) to allow this very cool Belt Tensioner Pulley to spin like crazy.
I do not like plastic stuff....DO like Billet Aluminum stuff (Oil Fill Cap, Dip Stick Handle, Belt Tensioner Pulley are examples)
I am NOT an NCRS person either
Old 12-26-2015   #9
efnfast
Craftsman makes a great set of bolt extractor sockets.
http://www.google.com/shopping/produ..._aHIn9mAGilakw
These things work wonders.
Old 12-26-2015   #10
Thanks
Well......did you get the oil drain plug removed?
What method worked for you?
