![]() Join Date: Aug 2006
I drove out to Jim's yesterday to help with replacing Charlie's heater ore. Driving out, noticed brake engagement point was a bit too low compared to what I am use to. Driving back, either I was focusing on this or got even lower. Brake warning light is not triggered and seem to have sufficient hydraulic pressure. Fluid level in the reservoir is normal and noticed no leakage. Anyone had similar issue?
#2 | |
![]() Does Charlie have heat?
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-20-2015 at 09:40 AM. |
![]() Join Date: Oct 2004
Later C4's have the "prime pipe" and ASR, I really don't understand nor have I read much about the later system vs the earlier but it might be something to look into.
#4 | |
Yes. Minus coolant dripping into the passenger side. I have no idea how you replaced the heater core without pulling the dash pad. We had his dash pretty much gutted to get to the heater core. Now I know what is involved. |
#6 | |
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
Pedal feel and firmness seems normal with the motor off. Once motor is started, pedal travels more than what I am use to before getting firm. Pumping doesn't bring the pedal up.
Anyone had similar experience? |
#9 | |
Troubleshoot Power Brake Booster Hold pressure on the pedal while you start the engine. When the engine starts, the pedal should drop about a 1/4", this indicates that the Brake Booster is working properly. If you have air in the brake lines the difference might be greater.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-21-2015 at 08:50 AM. |
#10 |
That drop is more than 1/4". Time to bleed the brakes. Actually, flush the whole system - lucky me!
