Old 12-18-2015   #1
edram454
edram454's Avatar
Default windshield wipers
does anybody know where to get the windshield wiper inserts for our cars. the aftermarket wipers available do not work since they are too high. i unfortunately was replacing my stock mint windshield today after it was cracked and ruined during installation of some upgrades at a shop. while it was out i removed the wipers and went looking for replacements and did not have any luck.
ed ramos #3028
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
Old 12-18-2015   #2
secondchance
Default Re: windshield wipers
I use to buy standard, same length wipers, remove inserts and replace the inserts only. About 3 years ago I switched to Trico Neoform beam type - even pressure across the entire length resulting in better, uniform wipe. Doesn't matter anyway since I quit driving my Z when wet.
Old 12-18-2015   #3
edram454
edram454's Avatar
of course I dont drive in rain but when I drove my car home from the shop it was a 8 hour drive and about 5 or those were in rain. I barely drove my car 200 miles the whole year until I took it for the upgrades and it was 500 miles each way. I will try removing the inserts and see how that works out. I think mine are the original wipers in there.
ed ramos #3028
EDRAM454
Old 12-18-2015   #4
JimZRyd
JimZRyd's Avatar
If I'm not mistaken I replaced mine with a set of the Rain X brand. No problems with clearance, but I'm not a rain driver either.
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 12-19-2015   #5
USAFPILOT
USAFPILOT's Avatar
i've been able to get factor GM wipers at the local Chevrolet dealer.
Old 12-19-2015   #6
HAWAIIZR-1's Avatar
I gave up trying to mess with inserts and this was the subject a little over a week ago on the ZR1 Listserver. Here is what was posted by Marc H:
Trico 20-2 fits '90 - '94. 20-4 fits the larger diameter pin on '95 - '96. These blades are exactly the same as the OE blades.
I ordered and received the Trico 20-4 from Amazon today for my 95 and it fits perfect; it took less than a minute to install.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 12-19-2015   #7
WVZR-1
That was an interesting discussion over there , I was a participant - wipers aren't that difficult to understand. I've been an "inset user" for years and years ago actually used to keep blades removed from others as spares after replacing inserts. I mentioned the -2 and the -4 fitment also.
I bought blades for my '90 truck this fall and it's the first blades I recall purchasing for a very long time with the exception of my "WINTER BLADES" which will generally do 2 years max.
Old 12-19-2015   #8
USAFPILOT
USAFPILOT's Avatar
the tricos would contact my hood, but the factory part will not. Strange I know.
Old 12-19-2015   #9
edram454
edram454's Avatar
thanks for all the replys. i will try the rainx brand to see if they fit. I appreciate all the different ideas and I know more than 1 will work.
ed ramos #3028
EDRAM454
Old 12-21-2015   #10
Roadster
Roadster's Avatar
If I remember correctly I ordered replacement pair from Advance Auto shipped to my house. Will have to look up the part#, but they are exactly the same as what is on there now.....
And as Craig mentioned in above post about the part#'s......
I looked up the part I purchased, this is for my 94.....
TRICO Exact Fit Wiper Blades......20" part# 20-2
also do not order part# 20-1, even though they read the same, because the metal part of the blade is raised and will interfere with the hood
1974 LS4 454 Vert
1974 L-82 355 Vert.
