![]() ![]() Those black spots are coming from the ZR-1 when it is started up cold. I have also noticed it smells a bit rich too. The car still has cats, Borla axle back and deleted center resonator. I have heard it has a custom tune, but he chip appears to be stock. |
![]() Join Date: Dec 2003
If that continues at startup, it may be an injector housing gasket leaking coolant into an adjacent cylinder.
To the cylinder head. The top side gasket of the injector housing is normally referred to as the plenum gasket.
Afterthought: if the injector housing gasket is the source of a coolant leak, it will be into any of the front 2 cylinders on each bank, i.e., cylinders 1&3, 2&4.
A quick & simpler check would be performed on a cold engine after full warm up. Remover the plugs on the cylinders mentioned, pull the fuel pump fuses( both primary & secondary). Have someone crank the engine over & look for coolant blowing out of a cylinder. It won't be continuous, just a quick puff.
![]() Join Date: Jan 2015
Probably silly thought: I wonder if someone could analyze that soot and tell its source (coolant/water, fuel, ...)
Maybe looking at the plugs would provide more clues, especially if 1 or 2 look odd while the others look good. |
#7 | |
I could never see it on the plugs because the amount was small and it only appeared in the exhaust at cold startup.
The plugs could also look steam cleaned.
#9 |
![]() Join Date: Nov 2007
#10 |
![]() ![]() Another pic. ![]() ![]() |
