![]() Join Date: Apr 2013
Hi All,
Does anyone have a link or know what CFM the stock LT-5 heads flow at? Thanks you |
![]() Join Date: Dec 2003
I have them somewhere if i find them i will post them for you.
May i ask why you want them? They mean nothing unless you test on same flow bench. Pete
![]() Join Date: Mar 2007
Copy from Corvette Forun
"Here's something that was posted on the ZR-1 Net by Greg Van Deventer: Here's some intake numbers from a stock 1990 cylinder head tested @ 28" H2O on a stock 3.900" liner with secondary port throttle assembly and clay radius... Lift CFM .1 92.78 .2 167.97 .3 222.01 .4 246.84 .45 256.86 .5 263.44"
Thank you for the posting. No problem, Just curious how they flow in comparison to other heads LT-1, L-31, Lt-4, LS1 etc.
![]() Join Date: Jan 2004
new LS stuff is way better but it's not all about "raw cfm" flow quality, tumble, mix, detonation reistance and of course flow velocity make the LT5 work pretty good depite the rather low bench numbers
a good set of ported heads will sneak up on 340 cfm and support well over 700 ponies above that you are a bit flow bound. FYI the out of the box new LS7 heads flow 370+ which stomps the living crap out of our heads but of course a 4 valve head has many other advantages such as lighter valves, less valve shrouding, low tension springs and pete is right, flow benches like dynos don't tell the whole story |
#6 | |
![]() Join Date: Jul 2005
There are other important things to consider. A 700 HP LT5 perform different and better than a 370 cfm flowing LS7. We brought a C6 Z06 on the same car weight like a C4 ZR-1 and did some acceleration tests. The LS7 pulled in spite of its 427 cui pretty modest.
Sam DR.Z/LT5-Performance 1990 #1822 with 383 cui |
#7 | |
