http://www.zr1specialist.com/HAT%20W...r%20sensor.htm
Has anyone done this mod themselves? Did it make a difference? |
![]() Join Date: Mar 2007
it very easy, not sure you will notice seat of the pants improvement, but every little bit helps. I put mine down in the well by the secondary vac pump reading outside air
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 12-06-2015 at 09:12 PM. |
![]() Join Date: Apr 2004
Moved mine to the plastic filter housing
#4 | |
Locating the MAT further upstream of the intake air charge provides a more consistent Intake Air Temperature signal BUT you cannot take advantage of it unless the calibration is modified to reflect that change. The stock calibration is expecting a nominal temperature of ~ 80C. At that those temps, the ECM uses intake air and coolant temps in equal parts to modify fueling. Relocation of the sensor effectively eliminates sensor readings of anything above 40C or 130F. At this temp, the ECM is using the Intake Temp over the coolant temp to regulate or modify the fueling. The result is that the motor will run richer than it should be. The purpose of the MAT/IAT is to help ECM regulate fueling so that it is consistent over a wide spectrum of intake air/coolant conditions. IMO, not worth doing unless the calibration is modified to accommodate the relocation. |
![]() Join Date: Apr 2007
I did this early on with the '93 (back in '95) and on the '95 Marc located it down in the grille opening. Can't say that one item makes a noticeable difference but it is logical that a more consistent and accurate ambient temp reading will feed better data to the engine computer. One of the little things that add up to a better running Z. --Bob
![]() Join Date: Nov 2007
And, what if the TB coolant is bypassed. The temp of the air horn is very close to ambient air temperature; within a few seconds of run time. I wonder about the impact (if any) that has? Hummmm....
Is this saying a possible 10 HP gain from moving it?
#9 |
Not sure if its a gain, or just not losing it to heat soak....so its not pulling timing. It takes 30 minutes to do and less than $20....can't hurt
#10 |
