Old 12-06-2015   #1
randy ransome
randy ransome's Avatar
Default Different Oil Leak
I have a leak on the driver side. It is coming from just above the header where a wire goes into the head. It has a tin bracket that holds a black plastic piece that the wire runs through, it's held in the head with a 5/16 bolt.
I figured it's some kind of sensor or something. What is this and how do you get it out?
My apology for not knowing what it is.
I know a lot about drinking if y'all have any questions about that.
Thanks
randy ransome is offline   Reply With Quote
Old 12-06-2015   #2
secondchance
Default Re: Different Oil Leak
Thanks
That sounds like camshaft sensor. Cam shaft sensor has a no ring. I believe it's held in place with the sensor bracket bolted in with a 7 or 8 mm hex head.
http://www.jerrysgaskets.com/seal-ca...or-90-95-11c5/
Old 12-06-2015   #3
Randy, bring some beer and come on over, I got a big tube of that black stuff we can stop any leak....
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 12-06-2015   #4
randy ransome
Yeah i figured it had an O-ring on it. I guess I didn't pry on it enough to get it to come out.
I'll give it another try after another drink of course. JK
Thanks
Old 12-06-2015   #5
randy ransome
I'll be there in about 15 minutes Steve.
Thanks Buddy
Old 12-06-2015   #6
Demps
Demps's Avatar
Thanks
Hey, hold my whisky...watch this...
Ted
Old 12-07-2015   #7
RICHARD TILL
Cam sensor. Changed mine several months ago. With the bracket off just rotate it left and right while pulling outward. Next time ur down this way, stop by and we`ll change it. Got 200,000 btu`s to heat ya if it`s cold. We`ll swap stories on Jerry Johnson and Mike Austin.
Old 12-07-2015   #8
randy ransome
Hey Richard, thanks for the offer. When I tried to get it out I didn't want to pry too hard. I'll try your technique.
I'm still planning on coming down to visit one day. I've been down to my sisters place a few times over the past several months, usually just helped with their place and headed home.
Old 12-08-2015   #9
edram454
edram454's Avatar
speaking of leaks... anybody ever have a leak from a head plug?? there are plugs on the underside of the heads near the firewall and I see seepage out of one of he plugs on the right head closest to the firewall. it is not a heavy leak but enought to have my cleaning 2 drops a month from my garage floor.
ed ramos #3028
Old 12-24-2015   #10
randy ransome
I put a new O-ring on my cam sensor and it's still leaking.
I felt up in the head and it feels like it's smooth in there.
Why does the sensor look like it has two places to put an O-RING?
I put the O-ring on the grove closest to the magnet end, is that correct?
Merry Christmas Everyone
