I've had the short block sitting in my garage taking up space and was about to put it out by the bulk pick up. But before I did, I wanted to see what was causing that horrible knock. Took me a while with hand tools, but finally got the cradle off and surprising saw no obvious damage on the mains or in the cradle bearings. so, I started with the side I was pretty sure the damage was on...left front, and sure enough:
Turns out, #1 rod big end spun a bearing and mains have no obvious damage..in fact look perfect. I will post a picture in a little while, but I guess the block isn't going to the recycler now ![]() I haven't checked 3-8 yet but #2 on the same journal looked fine.. The bearing does look thin..and the engine had about 135k miles and probably run for a long time with a hard miss due to the injectors before I got it so maybe a contributing factor? ![]() ![]() . Last edited by Torchred96; 11-28-2015 at 11:42 PM. |
Also, I imagine the crank is hurt on #1 as it looks like a lot of metal transfer to the journal from the bearing...but is that a repairable item or is it likely scrap?
![]() Join Date: Dec 2003
The crank may very well be fine, but would require qualified clean-up & inspection to be sure. LT5 cranks are nitrided steel & really tough. Because of the toughness, used crankshafts don't have much value or marketability. Definitely not trash though:-)
Thanks Jerry .I appreciate the feedback.
