Old 11-11-2015   #1
Default Full Power light on DIC 91-95
You guys are missing out on the best interior feature that exists on the 1990s
Makes me wounder what it would take to add an operating bulb to the dic of the 91-up???, Could you tie it to the console switch light or even make it come on when the sec are open...? Is the circuitry in place and can you just add a bulb?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 11-11-2015   #2
WVZR-1
Default Re: Full Power light on DIC 91-95
You would only need to match the filter to that of the later model to be sure that the balance of the filter was a match for the '91+. I'd think that you would use a wired bulb/socket and not rely on the PC for power. I'd think it relatively easy if you had no filter differences aside from the "FULL POWER".
Wired socket/bulb pigtail and a correct filter - nearly done.
You might be able to compare the various filters using the 8C-4 (vicinity of a '90) and compare it to the year desired.
Old 11-11-2015   #3
Thanks WVZR-1 I was hoping you would chime in, I'll start the research.
Steve
1990 Red/Red #1473
Old 11-11-2015   #4
This from my Mentor
"The panel has "full power" in the overlay. And the DIC panel has the necessary wiring on the tape to reel circuit board. The wiring is probably just absent. You could tap into the power circuit and take the feed to power the bulb.
A few guys in the past on 90-91 L98 cars used to use it for indicator light for a nitrous system."
