Old 10-30-2015   #1
Snaps
Default loud backfire
1990, previous owner installed aftermarket mufflers. When i turn the key to full and lay into it, between shifts or when i let off i get a very loud somtimes violent sounding backfire. Also usually my dipstick is a quarter of an inch popped out. Im thinking crankcase pressures? Should i be worried?
Snaps is offline   Reply With Quote
Old 10-30-2015   #2
Default Re: loud backfire
Does it have headers? or an aftermarket e-prom?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-30-2015   #3
Snaps
Might have a prom, skip shift is eliminated
Old 10-30-2015   #4
Kevin
Kevin's Avatar
Probably needs a tune
Old 10-30-2015   #5
KILLSHOTS
There's an anti-backfire feature (forgot the actual technical term) that Marc enables on his PROMs when you install headers. When I had mine installed, I sent him my PROM for an update and when I got it back and installed it, it was backfiring so hard I thought it would blow the exhaust off. I contacted Marc and he checked his records and noticed that he had forgotten to enable this feature and he took care of it right away.
Short answer: contact Marc and order a PROM with anti-backfire enabled. Good luck.
