Old 10-24-2015   #1
RussMcB
Default Secondaries Solenoid Vacuum Leak
Sharing this in case it helps anyone someday.
My vacuum pump was cycling after only being off one second, so I started testing the system to see where it was leaking. Eventually I determined it was the electrical solenoid. When it was at rest, the valve was not completely closing.
Since I didn't want to wait for a new part, I tried squirting a bit of grease-less lubricant into the two ports, and cycling the solenoid a few times by giving it 12v. After a few cycles it started holding vacuum. I reinstalled it, and now the vacuum pump will stay off for about 30 seconds.
Information from Dynomite's posts and Haibeck's web site were very useful for troubleshooting. Thanks, guys.
Old 11-05-2015   #2
G-Sting
G-Sting's Avatar
Default Re: Secondaries Solenoid Vacuum Leak
Interesting analysis and solution. Glad it worked out!
'94 ZR1 LT5 - Dark Red Metallic
'79 L82 4-speeds of fun
'96 LT1 Borla, H-pipe, TB, CAI (Sold)
"An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton
G-Sting is offline   Reply With Quote
