Old 12-17-2006   #1
HADI-ZR1
Default new C16 WOW!! Reeves you are the KING too!!!
Old 12-17-2006   #2
HADI-ZR1
Default Re: new C16 WOW!! Reeves you are the KING too!!!
but guys, it looks like new Z350 , ya??
Old 12-17-2006   #3
Z Factor
Z Factor's Avatar
Not really.
It would be nice to see other pictures from different angles.
Old 12-23-2006   #4
RedSled
Looks cool to me. Just don't make me polish it....
RedSled is offline   Reply With Quote
Old 12-23-2006   #5
Engine
* Supercharged 6.0 liter (366 in.3) V8, 90°, cast aluminum block and heads;
6-bolt, cross-bolted main caps; nodular iron crankshaft;
CNC-machined Callaway cylinder heads;
proprietary port and combustion chamber configuration
* Supercharger: Eaton/Magnuson Roots-style; with air/liquid intercooler integral to intake manifold. 44" Hg manifold pressure, absolute. (7 psig)
* Bore x Stroke: 4.000 x 3.622 inches
* Compression ratio: 10.4:1
* Horsepower: 616 bhp @ 6,200 rpm (SAE)
* Torque: 582 lb-ft @ 4,750 rpm (SAE)
* Redline: 6,500 rpm
* Valve train: investment cast 1.85:1 ratio rockers, 17-4PH stainless steel; chromemoly push rods
* Ignition system: coil per cylinder; Callaway UHC 8-sleeved silicone ignition wires
* Intake valves: 2.020-inch diameter; stainless steel
* Exhaust valves: 1.570-inch diameter; stainless steel
Fuel system: Increased flow (42 lb/hr) fuel injectors; auxiliary fuel pump controller
* Throttle body: 90mm diameter, drive-by-wire
Suspension
o Forged aluminum, unequal length, upper and lower control arms, front and rear
o Callaway/Eibach Multi-Pro coil-over suspension
o double adjustable dampers external reservoir
o 10-position compression control
o companion helper and tender springs supplementing composite leaf springs
o Callaway anti-roll bars, tubular steel, front and rear
Steering
o speed sensitive, magnetic power-assisted rack-and-pinion
o Turning Circle: 39.0 feet (lock-to-lock)
Wheels & Tires
o Front: 19 x 10 Callaway/Dymag forged magnesium/carbon fiber rims 295/30ZR19 Yokohama “Advan Sport” tires
o Rear: 20 x 12 Callaway/Dymag forged magnesium/carbon fiber rims 345/25ZR20 Yokohama “Advan Sport” tires
Brakes
o Front/rear: Callaway 6-piston (front) and 4-piston (rear) calipers with 355 x 32 mm diameter rotors (front & rear)
Dimensions
o Wheelbase: 105.7 inches
o Track, front: 62.1 inches
rear: 60.7 inches
o Height: 48.1 inches
o Length: 174.6 inches
o Width: 72.6 inches without mirrors
o Curb weight: 3,150 pounds (est.)
o Fuel capacity: 18 gallons
Fuel Economy
o City/Highway: 18/28 (manual transmission)
o 17/27 (automatic transmission) (est.)
Warranty
Vehicle/Powertrain: GM vehicle and powertrain warranties apply with supplemental Callaway 5-year/100,000 mile warranty on Callaway components; Callaway warranty also covers any GM engine parts compromised by failure of Callaway components
Performance (616 bhp, 6 spd Z51 Manual Transmission) Coupe vs. (6 spd auto)
o 0-60 3.3 sec. (3.5)
o 1/4 mile 10.97@129 mph (11.22@123mph)
o top speed 206 mph (automatic, untested)
o lateral acceleration 1.05 g
o stopping, from 80 mph 195 ft
----------------------------$$$$ 119,000 -----------------------------
I THINK I STILL PREFER THE C4 ZR-1 SHAPE THE BEST NOT TO MENTION THE $ PRICE $
Old 12-24-2006   #6
HADI-ZR1
WB9MCW,
I agree you
Old 12-27-2006   #7
ZR-1 Franz
Hallo from Switzerland,
I agree with you. And don't forget, the ZR-1 not only looks great, she
also is a car with reliability and durability. There are not many cars you
can put in the same category!
I wish you all a Happy New Year
ZR-1 Franz is offline   Reply With Quote
