![]() Join Date: Jan 2015
I bought a lightly used set of OBX headers and they are somewhat installed.
On the passenger side there is a tube and I'm not sure what it's for, and what I need to do with it. It's 3-4" long, about .75" diameter, attached to one of the primary tubes, pointing towards the front of the car. I can post a pic if necessary. I have removed the air pump, so if it's related to that, I guess I need to plug it. If so, any suggestions on how folks have plugged it (other than removing the header and welding a plug)? Thanks. |
![]() Join Date: Nov 2011
It's probably for the air pump. I believe a 3/4" NPT (pipe) plug will fit. - Steve
Thanks, Steve.
Here's a pic. |
![]() Join Date: Jan 2006
EGR takeoff for late models.
Ted |
Russ, is that just left open?
Doesn't look threaded. Not sure how you'll plug that. |
#9 |
![]() Join Date: Oct 2004
Why wouldn't you just "sweat" an appropriate cap over the tube or in the tube so as not to defeat it's purpose if resale ever became something you desired?
#10 |
I'm not too familiar with "sweating", but that's probably a good idea (to save the functionality). Thanks. I'll ponder how I might do that.
