Old 08-20-2015   #1
MuRCieLaGo
Default Difference between the years
Hi guys,
Is there somewhere I can find the differences between all the years? Especially for the front bumper... I searched just a bit, I thought it would be easier to find.
Thanks!
MuRCieLaGo is offline   Reply With Quote
Old 08-20-2015   #2
Kevin
Kevin's Avatar
Default Re: Difference between the years
91+ has the same bumper
Old 08-21-2015   #3
Originally Posted by MuRCieLaGo View Post
Hi guys,
Thanks!
The differences in body style are one thing.....the differences in LT5 engines by years are another thing
You can mix and match parts but you have to know what the differences are so you do not change functions while mixing and matching
I have even detected a difference from a few of the first 1990s (#72 for example) to the last 1990 sold to public (#3032).
Differences between 90', 91' and 95' Crate Engine Plenums and IHs
Old 08-21-2015   #4
Default Re: Difference between the years: PVC restiction
IIRC, installing a 92(?) head under my 90 IH results in a double restriction; one in the IH, and the later mo. head. I thought about it at the time and decided there was no issue with the redundancy. For 5+ years and 20K miles, it hasn't mattered, far as I can tell.
Old 08-21-2015   #5
There were more changes in the interior over the years than the body. Button tag colors changed from orange to white with some of the functions changing, LCD changes, seats, door panels, dash, console, rear storage boxes.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 08-21-2015   #6
Default Re: Difference between the years: PCV restrictions
Great information Paul......you are one of few who have the double PCV restriction (90' Injector Housing PCV Restriction and 91' and later Heads PCV Restriction). You are also one of the few who have thought about removing the stock PCV restrictions in the 90' Injector Housings
to avoid the Double PCV restrictions in the 91' and later Heads AND 90' Injector Housings.
PCV Differences between 90 and 91 Injector Housings
Old 08-21-2015   #7
Considering the question of "mix n match", ponder this:
Is there any proven advantage or disadvantage for eliminating the injector tip bosses in the IHs? e.g., when porting, the 90 IHs primary port boss is typically eliminated in all the 90 IHs I've seen, and it doesn't seem to do harm the performance (that I can tell). In fact, I believe by removing it one could easily argue a small increase in flow, due to less restriction; often touted as an advantage of porting the 90s (not making that unproven claim myself, doanchaknow...).
Last edited by Paul Workman; 08-22-2015 at 05:49 AM. Reason: typo fixed...original sent from my "auto-correct" cell phone.
Old 08-22-2015   #8
For a more comprehensive list of changes, goto the Registry Home page and look at ZR-1 Trivia under the INFORMATION tab. Lots of good reading there, but there were other subtle changes as well, in the cabin an "creature features" departments, in particular.
Old 08-22-2015   #9
MuRCieLaGo
I'll continue my reading on the main page, thanks Paul and thanks to the other guys here!
