![]() Join Date: Aug 2015
"Solutions" describe lifting the rear: "A Steel adapter has been designed and proven safe to lift the rear axle directly under the center of the rear spring mount using a floor jack." "The pipe adapter is captured between the rear spring mount bolts"
If I read this correctly, and looking at my car. the adapter will be in contact with the spring itself correct? Thanks, Roger |
I think it goes under the rear diff but I've never used that. I always use the factory jacking points to jack up the car
![]() Join Date: Apr 2007
Marc Haibeck used to make and sell jack adapters for use on the rear spring. I don't know that he still does, but you might contact him to see if he has one still. (www.zr1specialist.com). --Bob
I had good experience with the C4 EZ-Jack-Adapter from the GadgetMan:
http://www.corvettegadgetman.com/products3.html
Thanks for your feedback Kevin, WARP TEN and Jagpanzer
#6 | |
