Old 07-30-2015   #1
5ABI VT
Default Questions about the LT5 crankshaft. What makes it so unique?
Curious about the LT5 Crank. Ive contacted a few Crank suppliers and 2 already have told me they can build me what I want. I haven't asked the cost yet ... but I was expecting a straight up 'NO' reply based on what Ive read about LT5 cranks over the years being pricey and limited etc etc.
so what makes the LT5 so special? is there a reluctor wheel or something like that that adds to the cost?
My idea for my build will be as big of a bore as possible and as long of a rod as possible with an extremely lightweight crank, rods and pistons etc. Hollow or ti valves (32 valves is awesome until you have to buy new ones lol). If I do shell out for a build I will look at custom billet manifold options as I want to do something like an individual tb setup eliminating the Injector housings and Plenum entirely for short stacks and a large volume plenum... massive cams, 1500 idle is fine...ideas ideas..
Old 07-30-2015   #2
tpepmeie
Default Re: Questions about the LT5 crankshaft. What makes it so unique?
The issue is that there are no existing cores or patterns out there. Only Bryant and Moldex have written CNC programs to make the crank from billet. What you'll find is that any of the major crank manufacturers have the capability to reverse-engineer the OEM crankshaft and create the program. But that takes time, and thus the price is really really high.
Yes, there is a reluctor wheel in the center. And the oiling drilling is unique, as is the snout.
From what you've described, I'd recommend a 3.75" offset ground stock crank, and 6.125" rods w/ 1.025" compression height pistons. The stock crank is a high quality piece.
Sounds like you'll want a set of cam cores, too. I can help with that .
Old 07-30-2015   #3
Jagdpanzer
Jagdpanzer's Avatar
The LT5 crankshaft design is somewhat unusual compared to most V8 cranks. Main difference is the lubrication of all main and rod bearings is done via interconnecting oil distribution channels drilled the length of the crankshaft. Main thrust bearing location is also different than most as is the ignition timing wheel reluctor slots that you mentioned. Consequently there are quite a few more precision machining steps required to produce a LT5 crank compared to a typical small block Chevy or others like it. To my knowledge there are only two experienced aftermarket suppliers still doing our cranks, Bryant and Moldex.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-31-2015   #4
Hib Halverson
"Ideas, ideas"?
1. A really big check book
2. A really good engine controls engineer
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 07-31-2015   #5
Todd,
Ever sell your setup?
Old 07-31-2015   #6
5ABI VT
"Ideas, ideas"?
I keep going back and forth.. I know how motor builds go. Have to draw the line somewhere or else it blows the budget astronomically. That callaway aerobody and rebuilding my wheels is starting to look like a much better plan
Old 07-31-2015   #7
tpepmeie
Todd,
Which parts? I'm in the process of rebuilding it right now. Tried to sell the entire Build 1 valvetrain, incl. camshafts. I think I will put it together with those again, then upgrade later. The issue is not new cams (I've got billet cores), but all the custom complimentary parts which need to go with it--springs, retainers, seats, buckets, etc. Only going to do that if I can sell the other set.
Old 07-31-2015   #8
Karl
Karl's Avatar
Or call this guy up.
https://www.youtube.com/watch?v=Zx4dnUe8CdU
https://www.youtube.com/watch?v=hRWEA9aMOl0
I think this is the engine. I doubt the crank is stock
Old 07-31-2015   #9
Todd,
Yes the first build parts. Would make an interesting presentation for the Gathering next year.
Old 07-31-2015   #10
rkreigh
Originally Posted by Karl View Post
stock crank is forged and all you need.
with the turbos displacement isn't necessary and the short stroke can work out well.
Hg sealing on the open deck block is more of an issue. I think the AES liners and short block may help there.
that is one sexy beast! ya baby ya! (A Powers)
