Old 07-27-2015   #1
RICKYRJ1
RICKYRJ1's Avatar
Default Corsa X-pipe
I see posts about X pipes all the time but never one for a Corsa system. Does one exist, or system is best with the resonator? I dont mind louder.
Old 07-27-2015   #2
KILLSHOTS
Default Re: Corsa X-pipe
Corsa does not make an X-pipe. The Corsa resonator is an open design that has no restriction, so replacing it with an X-pipe wouldn't net you any HP.
Old 07-28-2015   #3
RICKYRJ1
RICKYRJ1's Avatar
OK, thanks
Old 07-28-2015   #4
Not being familiar with the Corsa resonator, do you mean to say that BOTH left/right exhaust pipes co-mingle the exhausts within the resonator?? (I was under the impression they remain separate, even w/in the resonator.)
Old 07-28-2015   #5
Gunny
Gunny's Avatar
I think the Corsa has an H-pipe at the front of the resonator ... no longer have a Corsa system so I can't go look ... maybe someone with Corsa can confirm.
Old 07-28-2015   #6
Yes it does.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 07-28-2015   #7
Karl
Karl's Avatar
I have a custom made stainless steel x pipe. Works great!
Old 07-28-2015   #8
Karl
Karl's Avatar
http://postimg.org/image/r2i7hnefn/
Old 07-28-2015   #9
Karl
Karl's Avatar
http://www.stainlessheaders.com/xpipeypipeade made here
Old 07-29-2015   #10
HAWAIIZR-1's Avatar
Prior to building the semi-custom exhaust from the stock system on my 95, I was going to have Dr. Gas build a 2.5 X pipe.
http://www.drgas.com/Tandem-X-Pipe-J...Only_p_52.html
Although I opted to go with a Magnaflow Tru-X muffler instead. I would consider calling Scott at Dr. Gas and consult with them or Corsa directly on why they decided to go with H instead of X. Not sure if the secret and patent behind Corsa RSC technology is in the resonators or mufflers. Removing the resonators will probably introduce drone/resonance; maybe there is power to be gained?
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
