Old 07-24-2015   #1
Coupe89
Default Diode Air Conditioning Clutch
Does anyone know what type of diode to use on the AC clutch coil?
I have 1N4004 diode but I think that for an 89.
Anything for LT5?
If not I'll give 1N4004a shot.
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
Old 07-24-2015   #2
Default Re: Diode Air Conditioning Clutch
Anything for LT5?
That should work as well for the LT5.. compressors and clutches are basically the same, LT5 compressor volume is smaller but i would not think that would be an issue
Old 07-24-2015   #3
batchman
A diode across a coil is there to absorb a surge when the magnetics release. It's not like it's a constant current thing. That diode should be fine.
GL,
- Jeff
[/I]
Old 07-24-2015   #4
John Boothby
John Boothby's Avatar
LT5 clutch is different than the standard. It is unique due to the higher RPM I believe.
When I bought my Z, the belt was shredded. I put a new belt on and within a week, it was shredded also. I looked through all the receipts that came with the car, and found where the a/c clutch had been replaced. I referenced the pn and it was for the LT1. I showed this to the dealer, and he replaced the clutch with the correct one for free, even though it was the previous owner who had it replaced.
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
John Boothby is offline   Reply With Quote
Old 07-24-2015   #5
WVZR-1
Anything for LT5?
I've seen this TSB by FourSeasons regarding the diode you mention but the TSB references the RS part number for that diode part #. RS # 276-1103 is their number for the # you referenced. Does it mean squat? Don't know.
http://www.4s.com/Upload/Four%20Seas...STALLATION.PDF
The GM TSB regarding all diodes:
http://www.corvetteactioncenter.com/...print-217.html
Old 07-25-2015   #6
Coupe89
Thanks for the info...
1990 ZR-1 #642
