Old 07-22-2015   #1
RussMcB
Default Exhaust removal questions (worth saving?)
I'm removing my original '91 exhaust to replace it all with aftermarket parts. The top two bolts behind the cats are tough to access and I haven't been able to break them loose yet.
1) Any suggestions for the best tools to use to get to them? I have a fairly good selection, but no success yet. I may run out to buy some wobble extensions to see if they might help.
- or -
2) Any reason why I can't just cut the pipes and be done with it? Is there a chance this 25 year old exhaust might have some value to someone some day? I hope to never use it again ever and I'd rather not store it for years only to eventually throw it away.
Thanks.
Old 07-22-2015   #2
Default Re: Exhaust removal questions (worth saving?)
When doing exhaust heat is your friend. A hand held propane torch will work. Be careful...
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 07-22-2015   #3
Racinfan83
Lot's of PB Blaster penetrating oil, and I used a socket with a u-joint to get em off my '90. Actually used the same bolts to put the new one on. It takes a bit of time and effort but my original came off all in one piece. I have it standing on end in the basement against the wall...
Old 07-22-2015   #4
RussMcB
Thanks for the suggestions. I sprayed it with breakaway fluid a few days ago, but the bigger problem is access.
Originally Posted by Racinfan83 View Post
<snip> I have it standing on end in the basement against the wall...
Yeh, that's kinda what I wouldn't like.
Do you think you'll ever do anything with it? In my case, it would probably would hang around for a few years until I finally decide to throw it away. If that's the case, I might as well cut it off behind the cats with a cut-off wheel. I can't really imagine it ever being used again.
Old 07-22-2015   #5
jimmy b.
jimmy b.'s Avatar
Save it, if its in good shape somebody could use it. Keep it high and dry. I just found a really nice original exhaust for my 94. Some day I'll put it on but for now I like my Corsa just fine.
by the way what do you plan on replacing it with
jimmy b. is offline   Reply With Quote
Old 07-22-2015   #6
Yes.....exactly
I use an acetylene torch on the exhaust manifold bolts as well as the Injector Housing Coolant Manifold bolts. On the Coolant Manifolds you have to heat the length of the bolt (on the housing) which extends through a hole in the Coolant Manifold (four bolts).
I use SS Bolts when re-installing the Exhaust System.
See Item #3 and Item #6 C4 Beam Plates and Installation
Old 07-22-2015   #7
RussMcB
I got a good deal on new OBX headers and slightly used aftermarket cats and a Borla cat-back system. I also took advantage of the ZR1.net Registry discounted price for a new SW crossover tube.
I went to a chassis dyno last week to get my "before" exhaust upgrade power numbers and they were lower than expected. I spoke with Marc afterwards and he said most likely issue is clogged original cats. I'm crossing my fingers that's true, and this exhaust upgrade should be +70 HP(!) :-)
Old 07-22-2015   #8
Fully Vetted
Fully Vetted's Avatar
I've still got my original exhaust down at the shop wrapped in bubble wrap. Along with the original gear shift, gear set, wheels, tires....It all came with the car.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 07-23-2015   #9
KILLSHOTS
Headers and a cat-back (with cats) and you were expecting 70+ HP? Try half that, at the very maximum. I doubt my headers (without cats) and Corsa added any more than 25 or 30 HP, even after Marc reworked my tune to add fuel for the headers.
As far as what your stock system is worth, just list it for sale and you'll find it's worth nothing, unfortunately. I made sure to keep most of my pristine 15K mile system when I replaced it, and it all went straight in the trash when I sold the car.
Old 07-23-2015   #10
RussMcB
I shouldv've included a smiley when I typed that. :-) It was tongue in cheek - a reference to someone else's recently post about a 70HP claimed improvement from an exhaust upgrade.
However, *if* my current exhaust is truly clogged and is costing me, say, 25-30 HP, then it is possible I will gain more than the normal upgrade increase because I'll be fixing the problem to get it back to normal, PLUS getting the normal improvements from headers and exhaust.
I'm not worried about any magical numbers. I just want it to be as strong as it should be, and sound better (it's pretty quiet now).
