Old 07-20-2015   #1
Default Another question about a Hurst shifter install.
How much more difficult is the shifter installation with the exhaust left in place? I'm going to dig into this providing I don't have to drop the exhaust. I'm working in a 1 car garage so I want this to be as painless as possible.
Old 07-20-2015   #2
RussMcB
Default Re: Another question about a Hurst shifter install.
I think I read that all work is done from inside the car (not from underneath), so, no, the exhaust can stay in place.
I'm sure someone will chime in with a definite answer soon.
Old 07-20-2015   #3
From what I've always read the infamous pin needs to be knocked out from the bottom side of the car. It would be great if everything was done from inside the car but I don't think that's the case.
Old 07-20-2015   #4
RussMcB
Ah, well in that case I'm glad you posted the question. I am in the middle of a new exhaust/Hurst shifter project, so I'll benefit from the answer, too.
Old 07-20-2015   #5
1991ZR1
You need to work under the car to remove the pin. I think someone has done it without removing the exhaust but I had to remove it even though I don't have big hands. Removing the exhaust is not that bad. If you have stock exhaust, it comes off in one piece. I balanced the exhaust on a floor jack and pulled it straight back.
Some people have had pins that came off easy but mine was tight. If your pin is tight, it helps to use a punch that is heavier. I don't know why the size of the punch makes a difference using the same hammer but it did. I wonder if someone could make some kind of puller to remove that pin.
1991ZR1 is offline   Reply With Quote
Old 07-20-2015   #6
5ABI VT
Dropping the exhaust is really easy.. few hangers and and bolts and slides right off. I did the same just used a floor jack near the center and rolled it back out of the way. If you don't know where the pin is then it might be impossible without dropping the exhaust. If you can pull back the boot you should be able to see it and if you can fit something to punch it out youre good without dropping it.
Old 07-21-2015   #7
Billy Mild
I didn't remove the exhaust but it definitely cost me time in the end. Also I would spray the PIN with some penetrating oil before trying to hit it.
I didn't have a punch so that made a difference.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 07-21-2015   #8
I did the Hurst in my Z in the car..
from what I recall, the exhaust will need to be dropped..
Old 07-21-2015   #9
Demps
Demps's Avatar
It can be done with exhaust in place. Easier with an aftermarket system.
BUT, you will spend more time working around exhaust than it takes to remove it.
Bring it to Vegas in October and we'll put it on.
Ted
Old 07-21-2015   #10
Tough getting a clean shot at the pin w exhaust in place.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
