Old 07-11-2015   #1
JimZRyd
JimZRyd's Avatar
Default Installing Stainless Steel Brake Hoses
Need some advice Brothers. I'm in the process of doing a few projects on my 94 and have gotten to the point of replacing the rubber brake lines with braided stainless steel ones. I've ran into a road block as I cannot for the life of me get the darn hard line loose at the connection to the rubber hose. I initially tried with just a regular wrench and that wasn't working, so I went and bought a set of line wrenches and tried the appropriate size, 12 mm is what I looked up, and still cant get it loose. Tried so hard on the right rear that I rounded the edges to the point I'm going to have to get someone to help me replace it, so I moved to the left rear and cant get it to budge either...Stopping before I round that one off as well. Anybody got some words of wisdom or bag of tricks for this??? Any help is greatly appreciated
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 07-11-2015   #2
Default Re: Installing Stainless Steel Brake Hoses
Hang on.......what is a regular wrench
Anyway...........do not use Combination Open End Wrenches (the open end) as they tend to open just a tad rounding off the Hex when trying to break open a hard to break line. Is this what you are working with?
Old 07-11-2015   #3
JimZRyd
JimZRyd's Avatar
Thanks! Yes that's the connection I'm talking about. I couldn't get it to budge with the open end wrench so I went and bought a set of proper line wrenches. The 12mm line wrench I used is what rounded off the right rear hard line nut. Tried it on the left rear and stopped just as I could feel it start to round. It's like they are frozen solid. I've soaked them with PB blaster again and will see if I can do anything with it tomorrow.
Jim Zorgias
Old 07-11-2015   #4
Dmod81
When mine were frozen I used pb blaster and CRC freeze off over the course of a couple of days (with tapping for vibration). I also used heat very carefully. Mine ended up rounding off too even with line wrenches, so I used vise grips on a couple.
Dmod81 is offline   Reply With Quote
Old 07-11-2015   #5
I understand the feeling of slipping a wrench rounding off a hex.....I would try large Vice Grips at that point to hold the bottom steel line hex. The Break line Hex is larger and an open end may allow you to apply enough torque to break the fitting loose. Otherwise another Large Vice Grip. I have never tried heat on a brake line but heat would prolly not bother as you are discarding the rubber line anyway
Originally Posted by Dmod81 View Post
When mine were frozen I used pb blaster CRC freeze off over the course of a couple of days (with tapping for vibration). I also used heat very carefully. Mine ended up rounding off too so I used vise grips on a couple.
We are thinking exactly alike as I was posting at the same time
Old 07-11-2015   #6
JimZRyd
JimZRyd's Avatar
Thanks. I'll try the vice grips and see what happens. Right now I'm a little worried that I might not be able to get the hard line tight enough after replacing the rubber lines because of the rounding and have no alternative than to perform a brake line repair job , such as splicing another end to the hard line. Never tried that and really don't want to either.
Jim Zorgias
Old 07-12-2015   #7
If you break the connection loose with vice grips you can definitely get the connection tight enough with vice grips when re-assembling. You can dress up the Hex with a file or small hand held grinder. I would never splice a brake line.....I would have to look but I am thinking the steel brake line can be replaced as there are many ZR1 chassis around and the steel brake lines are not in high demand.
Old 07-12-2015   #8
JimZRyd
JimZRyd's Avatar
That sounds encouraging. I'll try and tackle it later today with vice grips and hope for the best. I agree, I don't want to do a splice but was thinking worst case scenario. Replacing the whole line def would be a better alternative. Hopefully I won't be going that route.
Jim Zorgias
Old 07-12-2015   #9
Should really use a flare nut wrench.
http://www.grainger.com/product/SK-PROFESSIONAL-TOOLS-Metric-Standard-Flare-Nut-WP171919/_/N-99z?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/12C515_AS02?$smthumb$
Also, I use Kroil. MUCH better than PB Blaster. Available by mail.
Old 07-12-2015   #10
5ABI VT
I have renewed faith in Vice grips> I got a smushed and rounded ZF drain plug out that had just a few threads peeking out off and out of the trans with Vice grips when all else failed. I agree 100% if you can get the lines loose with them tightening with them is more than enough.
