07-04-2015 | #1 |
What's the best way to disable the antenna?
Title says it all. My new after market radio puts the antenna up regardless of the input source. Drives me crazy. I never listen to terrestrial radio.
07-04-2015 | #2 |
Re: What's the best way to disable the antenna?
Can't you just unplug the antenna from the radio?
Jim Zorgias 1994 ZR-1 Admiral Blue/Black #245 1996 Callaway Supernatural 450 1990 Callaway Supernatural 490 / CR-1 #7 |
07-04-2015 | #3 |
My radio does not work....so im not sure about the zr1.
my 94 Lt1 had a plug under the trim that surrounds the bottom edge of the hatch...only a few screws. Was easier than pulling the radio |
07-04-2015 | #4 |
Yeah...Or, you could just leave the antenna up and park the car near any high school. (I guarantee your antenna will not driver you crazy after that!!)
07-04-2015 | #5 |
How did you wire in the aftermarket radio? There is a blue wire at the radio tuner box you can disconnect
07-04-2015 | #6 |
Didn't know if there was something easier or more convenient than pulling the radio.
07-04-2015 | #7 |
What year car? The radio receiver OEM wiring is easy to get to without pulling radio
07-04-2015 | #8 |
07-04-2015 | #9 |
Most of the after markets sell a bypass switch. It's just a wire splice on the passenger side. It comes with a switch that I mounted in my center console. When I want to listen to the radio I just flip the switch and the antenna goes up. I did it because I got tired of it going up and down when listening to CD's.
Jim |
07-04-2015 | #10 |
push it down while it's up. It will destroy the ribbon and there ya go. Though I would like to find a way to keep it from going up on my 90 when listening to tapes
