Old 06-27-2015   #1
thirstyzr1
Default Oil in number 6 cyl.
Hi All,
Its June and I still have not started my stock 90. Has been stored since last fall in my heated garage. Fresh oil after parking it.
Decided to change the plugs before putting it back on the road next week.
I pulled out number 6 plug and its covered in oil. The car ran fine all of last year.
Any thoughts?
Thanks, Jeff
thirstyzr1 is offline   Reply With Quote
Old 06-27-2015   #2
Z06scentair
Z06scentair's Avatar
Default Re: Oil in number 6 cyl.
Time to remove the cam cover and replace the o-rings. They seal the head to cam cover.
Z06scentair is offline   Reply With Quote
Old 06-27-2015   #3
As stated you need to remove the Cam cover and replace the Oring plug seals. GC
Old 06-27-2015   #4
thirstyzr1
Ok thanks for the input.
There are 2 mechanics that have LT5 experience within an hour of me. Drive or Tow?
It was only # 6 that was oily.
Old 06-27-2015   #5
Z06scentair
Clean the plug off and stuff a rag down the bore to remove as much oil as possible. Put the plug back in and drive.
Old 06-27-2015   #6
RussMcB
Maybe crank the engine a few revolutions before putting the plug back in to give it a chance to push the oil out of the plug hole, just in case there's enough oil in there to cause hydraulic lock (probably not, but ...).
Old 06-27-2015   #7
thirstyzr1
Thanks for the replies Gentlemen.
Old 06-27-2015   #8
Mystic ZR-1
Mystic ZR-1's Avatar
Originally Posted by thirstyzr1 View Post
Hi All,
Any thoughts?
Thanks, Jeff
Do you mean oil on the electrode or the outside of the plug?
Old 06-27-2015   #9
Hi All,
Decided to change the plblugs before putting it back on the road next week.
Any thoughts?
Thanks, Jeff
Covered in Oil means what?
Lets assume Oil outside of the plug.......
How much Oil and when is the last time you checked the #6 plug?
If the plug is just a bit oily and it has been a long time, just clean the plug, clean the port and reinsert the plug and drive. I had the situation one time and it probably took several years to get a bit of oil in the Plug Socket.
In addition it could be high crank case pressure and your PCV system clogged a bit forcing the oil past #6 "O" ring. Could even be that someone had the Cam Covers off and got oil in the #6 Plug Socket. If it is just a bit of oil and the plug a bit oily, just clean things up and drive. Check again next oil change.
Old 06-27-2015   #10
thirstyzr1
By the time i pulled the plug out in was covered including the threads...but considering how oily the socket was i may have just been pooled up. Threads would have been exposed when i backed the socket out.
The wires were replaced in fall of 13 along with all the usual things under the plenum. I ment to do the plugs last spring but just forgot about them. I am moving and was cleaning in the garage. Found the plugs and did them today.
