Old 06-27-2015   #1
Johnny5
Default steering noise/issue
I am experiencing some sloppyness in my steering right at top center of the wheel. It feels as if it has a few inches of play (not responsive enough, my 1994 LT1 was definitely more responsive hence why i think something is worn) and it is more noticeable at higher speeds. Also i turned the wheel back and forth with the car off and something is making a knock noise. My brother thinks it may be a worn steering box. Anyone have any experience or advice with these symptoms?
Johnny5 is offline   Reply With Quote
Old 06-27-2015   #2
Default Re: steering noise/issue
You may want to check the steering rod coupling and tie rod ends. You have rack and pinion steering (no steering box) and yes it can ware out.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-27-2015   #3
Johnny5
Thanks, how would i go about checking that to see what to replace?
Old 06-27-2015   #4
Have a buddy move the steering wheel while you check for whats lose or where the play is. Do it with and with out the car running. Jack up each wheel and check for play.
Steve
1990 Red/Red #1473
Old 06-27-2015   #5
lbszr
lbszr's Avatar
If it turns out to be the rack and pinion, turnone-steering.com seems to have a good reputation for rebuilding. I found a rebuilt on at rock auto without a core. I'll be sending my original to turnone.
If I rock the steering wheel with it not running, mine has a knock from in the rack with the old and rebuilt, but the play is gone.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 06-28-2015   #6
Johnny5
maybe the knock is normal for this rack and pinion but I am almost certain the play is not. The response should definitely be sharper than what I am experiencing. I have to check everything out/jack up the front 2 wheels when I have time.
Is the steering in our ZR1s any different than the base C4? and is rebuilding our rack and pinions the only option? (no new offered?)
Turn-one steering looks great but I am in NJ. If I have to pay to rebuild the system Id rather just bring the car somewhere in NJ instead of taking everything apart and paying for shipping twice. Does anyone know of good shops in or around NJ?
Old 06-28-2015   #7
batchman
I'll echo the suggestion for a very simple check. Have *anyone* sit in the drivers' seat, key on/engine off. With the hood up, put your hand flat on top of the drivers' front tire. Have your assistant slowly move the steering wheel until you feel the tire want to move, then tell them to reverse direction and find that point as well. With that settled, have them lather/rinse/repeat while you watch the steering column rag joint and then the tie rod end at the spindle. You may need to take the plastic cover off the rag joint to see the far side of it. My bet is that's where you find your slop, but if it's not, and the tie rods ends at the spindle aren't moving before you feel the tire move, then it's probably inner tie rod end(s) or the rack itself. If it's not the rag joint, repeat the tie rod check on the other front tire.
The pump is different. The rag joint is different, and "soft" - they went to the old style canvas coupler (hence "rag") as opposed to the "hockey puck" that's on our '88, although that is a Z51 car and I'm not sure which style a base model has. The only other difference I'm aware of is quick vs slow steering racks, most C4s have the slow one except for (I think only) Z51 which got the (very very good and very very rare) quick rack.
My wife bought the ZR-1 in order to have a faster C4 than her '88 Z51; we were pretty surprised at the difference in steering. I have come to believe this was intended to keep their well-heeled new car buyers from twitching off the highway at 175mph. We switched the rack right away and it was still lacking the crispness of the Z51 car. I picked up one of the "hockey pucks" and swapped it, much more direct now.
Anyway sorry for the long post but a lot of that journey started when I noticed the rag joint had play in it...
on edit after your edit: In the highly unlikely event you need to get your rack rebuilt, I would not hesitate to send the rack to Turn One. You can probably get a parts store re-man put in at your corner garage, but IMHO "There be dragons there".
HTH,
- Jeff
[/I]
Old 06-28-2015   #8
lbszr
lbszr's Avatar
If it's not the simple things. There is the possibility the rack preload adjustment needs adjusted back to factory specs. I tried it on mine before replacing the rack and it didn't help the play, but you never know, free to try. The adjustment is hard to gain access to.
Mine was really bad, it started with a catch that could be felt while turning the steering wheel. It even started wheel shimmy in hard turns on a road track.
Corvette Recycle has NOS rack if you want new. $750.00.
Old 06-28-2015   #9
Johnny5
my car only has 28k miles so i bet it is something stupid like the lower balljoint on the control arm or some play underneath that plastic cover. Im going to jack it up next weekend. I hope it is not the rack and pinion.
Old 06-28-2015   #10
Johnny5
Smile Re: steering noise/issue
i am coming from a 1994 corvette lt1 with the adjustable suspension, maybe the steering in those cars are just felt more crisp and direct than the zr1. I guess I'll find out Friday (im off work ).
