Old 06-26-2015   #1
SteveCanyon
Default 90 Keyless Entry
Can someone recommend a good keyless entry system for my 90? Don't need anything fancy, just want something for the doors and trunk and fairly simple to install. Thanks!
SteveCanyon is offline   Reply With Quote
Old 06-26-2015   #2
Kevin
Kevin's Avatar
Default Re: 90 Keyless Entry
factory 93 system
Old 06-26-2015   #3
SteveCanyon
Is that the same as this?
http://m.ebay.com/itm/301671616985?nav=SEARCH
Old 06-26-2015   #4
secondchance
Originally Posted by SteveCanyon View Post
No. That is not factory 93 system. However, that may be a better retro fit GM system.
Old 06-27-2015   #5
efnfast
I had a local guy do mine. I don't know the make, but he did entry, hatch, and windows. The only problem has been the relays in the door have gotten water in them. He sealed them better and have not been a problem since.
Old 06-27-2015   #6
The VKE1000 is a GM over the counter system that used to be sold GM parts departments.
Old 06-27-2015   #7
IMZZ
Has anyone actually installed a 93 keyless entry system on a earlier car. Not the VKE1000.
IMZZ is offline   Reply With Quote
Old 06-27-2015   #8
SteveCanyon
So is the VKE-1000 plug and play or do I need to buy anything else to make it work?
Old 06-27-2015   #9
No VKE is not plug and play. Soldering and understanding of the qiring of both come into play. I had a VKE for my last vette. This one has a Directed Electronics kit. Funny thing is the wiring is 98% the same as the VKE yet much cheaper
Old 06-27-2015   #10
SteveCanyon
Thanks for the info on the VKE. I may see what some local installers have and,are comfortable installing.
