I bought my 1991 Z a few weeks ago and drove it from Northern MI to TX...without any sound from the radio, except low static. It was a long time to be alone with my thoughts!
Regardless, I am now tackling the repairs. First off, the antenna was stuck in the up position. I could hear the motor run when I turned the radio on and off, so i figured it was the nylon cable in the mast. Ordered one off of eBay and got everything working on that end. I did have to disassemble everything because the nylon cable was in about 4 pieces inside the unit. Next, I figured it was a safe bet that the 4 amps in the speaker enclosures needed to be rebuilt, so I sent them to Doctor Don and he had them back to me in 48 hours! Now, at full volume, I have low, low sound that is audible only in a quiet garage without the engine running...progress, I guess. Called Doctor Don and he said it was the CDM, which I was hoping to to avoid since I basically hate "contortionist" projects. I did watch the youtube vid on getting it out and that helped! I was able to get the CDM out in a little under 30 minutes. So, off it goes tomorrow. Who knows, maybe I'll have sound by the end of the week! |
#2 | |
Be careful you do not break the plastic tabs on the plastic plate under the CDM when re-installing. I removed all those electrical tabs from the plastic plate squeezing the pop out using forceps then re-installing the electrical after I got the plastic plate back in place.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-21-2015 at 01:53 PM. |
![]() Join Date: Apr 2004
I just had my CDM repaired and an I-Pod hook up added to it. Works great!!
http://www.carstereohelp.com/corvette.htm
