Old 06-17-2015   #1
carter200
carter200's Avatar
Default Question for the guru's......
Do you know where the turn flasher unit is and how you get to it. Friend of mine ask me and I figured you guys would help me so I can tell him. Thanks
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 06-17-2015   #2
tf95ZR1
tf95ZR1's Avatar
Default Re: Question for the guru's......
Under the driver's side dash. Remove the hush panel, contort under
the dash like a teenager, its to the door side of the steering column.
How do I know?
http://www.zr1.net/forum/showthread....hlight=flasher
PS: I had to remove a metal dash brace to access my flasher.
Old 06-17-2015   #3
Once you remove the metal panel it's right there.
Old 06-17-2015   #4
carter200
carter200's Avatar
Thanks guys. I forwarded the info and pic.........
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 06-17-2015   #5
If he replaces it with an electronic flasher VS. a mechanical flasher he can upgrade his lights to LEDs
Old 06-17-2015   #6
carter200
carter200's Avatar
GC,
He's old school but good to know........thanks
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
