Old 06-16-2015   #1
Vette73
Default WTB 410 GEARS
Figured i would put it out there....Anybody looking to sell 410 viper gears..
Eventually will do this mod on my Z after a decent amount of research..
Thanks....John...
Vette73 is offline   Reply With Quote
Old 06-22-2015   #2
Leroy1
Default Re: WTB 410 GEARS
I have a set of "new" gears (over 15 years old but never installed). Included is a new crush sleeve and pinion nut.
They came with a '91 ZR-1 that I bought, but never installed them. I was told they are the Viper Super Dana 44's, but I have no way to verify.
Price is $300 plus shipping. If you know someone in central/east Texas that can inspect and verify to your satisfaction what they are, feel free to have them contact me. Or I can forward to you the stampings and other ID on the gear set.
S. L. Sikes
6102 Willow Springs Road
Burton, Texas 77835
979-251-7167
LeeandMaryjane@gmail.com
Leroy1 is offline   Reply With Quote
Old 06-22-2015   #3
WVZR-1
S. L. Sikes
Burton, Texas 77835
979-251-7167
Measure the outer diameter of the ring gear and confirm either a 216mm or a 226mm dimension OR a number very close to either of those #'s. That would indicate a good bit regarding the package, you might want to see if the ring gear bolts are 3/8 or maybe 7/16. There should be a 5 digit number on each gear - you could post those also.
Old 06-23-2015   #4
Vette73
Hey Leroy....Yes you can post the findings or send me a PM.....I'm not to familiar with what I would be looking for to verify but I can show my mechanic to see if they are authentic ..
If they are I would be interested ..
Thank you...
Old 06-23-2015   #5
Jagdpanzer
Jagdpanzer's Avatar
Here is an old post on the subject of gears
http://www.zr1.net/forum/showthread....ighlight=viper
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-23-2015   #6
RussMcB
After John (Vette73) gets his, I would like to buy some, too (sometime within the next year or so). Thanks.
Old 06-23-2015   #7
Leroy1
These are the numbers stamped on the ring gear:
03 15 98 (mfg date?)
Dana G 48761
P8L165 41 10
28
Etched on the ring gear is the number "5".
Ring gear outside diameter (gear side) is ~ 8.75".
Ring gear outside diameter (bolt side) is ~ 8.125". This includes the bevel.
Ring gear retaining bolts are 3/8" NF, 10 each, right hand thread.
These are the numbers stamped on the pinion gear:
Dana G 48409
V1L 351 41 10 A
04 02 98 (date?).
Hope the above helps everyone identify this gear set.
Old 06-29-2015   #8
RussMcB
Leroy, thanks for the email yesterday. Yes, I'll take them as soon as I can confirm they will work with my diff.
On edit: I have decided to pass on these at this time.
Old 06-29-2015   #9
Vette73
Can anyone on the forum give me a price for 410 viper gears? Also you need to purchase an install kit either way.....From what I understand the part alone is really not that much new......Gears are one part you do not want to buy used...
Old 06-29-2015   #10
dredgeguy
dredgeguy's Avatar
Our own "Dr" Phil - Jagdpanzer gave me the following list when Wazoo did my gears. I can tell you that I am enjoying them, best mod to really enjoy driving the car. It will pull with whatever gear you are in. I got the gears from Just Differentials but they are also available from Mopar as listed below. Just check prices, I hit it right 6 months or so ago with a good sale and free shipping. Good luck
- Mopar </SPAN>Viper 4.10 gear set PN P 5007043 http://www.moparonlineperformance.com/product-p/p5007043.htm
or
http://www.justdifferentials.com/index.php?main_page=product_info&products_id=3383& zenid=cc2a704ef501c52fed154f7950669ef4
- Haibeck 4.10 Speedo gears http://www.zr1specialist.com/HAT%20Web/products/Speedometer%20Correction%20Gears.htm
</SPAN>
- Mobil 1 75W-90 Synthetic Gear Lubricant (2 qts) http://shop.advanceautoparts.com/p/mobil1-synthetic-gear-lubricant-ls-75w-90-1-qt.-104361-98w573/7070039-P
- 1 x GM posi additive PN 88900330 at your local Chevy dealer parts counter
- Corvette Dana 44 rebuilt kit http://www.justdifferentials.com/MKD44HD-VET-p/mkd44hd-vet.htm
- Right Stuff gasket maker http://www.permatex.com/products-2/product-categories/gasketing/gasket-makers/permatex-the-right-stuff-gasket-maker-detail
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
